leave the vette in reverse?!
Old 05-20-2009, 09:44 AM
m25l
m25l's Avatar
Default leave the vette in reverse?!
had my vette for less than a month and it wont start.. i even tried jumping and it wont start. called the dealer and guy said i have to leave it in reverse when i turn it off or some feature or another stays on??? warning to others? or can anyone verify this for me?
Old 05-20-2009, 09:46 AM
Wayne O
CF Senior Member
Support Corvetteforum!
Wayne O's Avatar
I believe only the 2005 C6 with the 6-speed (manual) transmission required parking in reverse.
VettedCandidate
VettedCandidate's Avatar
Need more detail like year of car, mileage, etc.
m25l
m25l's Avatar
hmmm i have the 2008 c6 6-speed. does it still apply to my car?
Old 05-20-2009, 09:47 AM
m25l
m25l's Avatar
4k miles on it almost brand new
Old 05-20-2009, 09:49 AM
VettedCandidate
Call your dealer again and tell him to get his poop in a group and take care of this.
Old 05-20-2009, 09:51 AM
evoman
evoman's Avatar
Old 05-20-2009, 10:05 AM
LEXUS430
LEXUS430's Avatar
the 2005 c6 manuel had to be left in reverse when shutting off other all the computer systems stayed on and drained the battery,i've had 2 other c6's an 08 vert and an 08 z06 and neither has to be left in reverse turn them both off normally and i've never had a problem
Old 05-20-2009, 10:38 AM
eboggs_jkvl
Moderator/Tech Contributor
eboggs_jkvl's Avatar
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,810 Likes on 2,058 Posts
2015 C7 of the Year Finalist
My '07 sits in neutral when off. DBS is not an issue any more. The '05 M6 had this issue and has been corrected with a software reflash.
Elmer
Old 05-20-2009, 11:04 AM
DSOMvette
DSOMvette's Avatar
St. Jude Donor '09
Elmer
I have an 05 M6 also and have always made it a habit to park the car in reverse on any manuel shift. While it has not been an issue with me What can you tell me about the reflash, did the dealer do it and did they charge for it? If not who did it?
Old 05-20-2009, 11:07 AM
6spdC6
6spdC6's Avatar
Location: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
Only the 05 Manuals and EXPORTS have to be put in reverse to be shut down. After the vehicle is off it can be put in any gear.
Not sure if EXPORTS include Canada & Mexico, but the Europe bound cars do unless that recently changed!
Old 05-20-2009, 11:08 AM
Tblade
Tblade's Avatar
Yes, it has to be an 2005. Been there, done that,lol.
/\ Same question-what king of a reflash did you get?
Thanks!
Old 05-20-2009, 11:11 AM
C6Buddy
C6Buddy's Avatar
yes, I would also like to know if there is a fix for my 05. I can't stand having to put it in reverse. Plus, every time I go to Chicago and have it put in the hotel garage, they never put it in reverse and the battery dies. How do we fix this??
6spdC6
6spdC6's Avatar
I had the reflash done with my 05. The dealer did it, and it was free then. Takes about 15 minutes. If I remember correctly the # of the reflash was. P1C188B
Old 05-20-2009, 11:14 AM
6spdC6
6spdC6's Avatar
No way to fix that I TRIED, somehow this is covered by federal law.
They cannot bring the 05 up to later specs, it ALWAYS has to be shut down in reverse.
My fix was to get rid of the 05 and get a 07 Z06!
Old 05-20-2009, 11:24 AM
eboggs_jkvl
I'm confused! I thought the reflash of the software eliminated the mandatory reverse position when shutting down the engine? What gives?
Old 05-20-2009, 11:41 AM
WAwatchnut
WAwatchnut's Avatar
The reflash was to correct problems associated with DBS - even when the car was properly shut down, some electronics were staying on, causing batteries to go dead.
The reflash did not change the shutdown sequence for any car, only addressed electronics staying on when they weren't supposed to.
To leave the vette in reverse?!
Old 05-20-2009, 11:46 AM
eboggs_jkvl
So.... You STILL must put it in reverse before you kill the engine? What happens if you don't?
Old 05-20-2009, 11:50 AM
JJC5
JJC5's Avatar
My understanding is that even though it is parked in reverse, there are times when it still doesn't shut down everything. The reflash changes the software to make sure the vehicle is completely shut down although it still has to be left in reverse. There have been numerous '05s that have had repeated "dead batterty syndrome" (DBS) even though they have been shut down in reverse. Federal law required the shut down to be in reverse for some auto theft precaution only for '05.
Old 05-20-2009, 11:57 AM
corvettezman
corvettezman's Avatar
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
No question about it, all 05 manual trans cars will have to be in reverse for the battery not to go dead when parked. No fix, no getting around it , NADA
Now as far as the OP, his car is an 08, and if the dealer told him he needs to shift his shifter to reverse to keep the battery from dying, then he needs to find a better qualified dealer.
Quick Reply: leave the vette in reverse?!
