Installed an NPP/Z06 Mild Adjustable Control Kit
I installed the NakidParts NPP/Z06 Mild Adjustable Control kit Link and now I have the best of both worlds. Flaps all the way open with the M2W switch, or flaps barely open in the mild (normally closed ) position. It took about 10 minutes to install the clamps.
You can see one of the clamps in the picture below, which only allows the flap in that exhaust pipe to close down to about 1/6th open. I know it doesn't sound like that can make much difference, but it does.
The exhaust sounds great all the time now in the mild mode...a bit louder and deeper than stock (flaps completely closed). And when I want it really loud, I hit the M2W switch.
I tried a number of lock down positions to get different variations of loudness. It didn't take long to find the sweet spot for my taste.
I posted this a few months ago, but am so pleased with the results, I had to post again. The Mild2Wild switch is great for wide open, but for those of you with NPP who want just a tad bit wilder sound when the flaps are closed, this is a great solution. It's adjustable to just the right sound.
Just ordered mine 5 minutes ago.
I have a complete 07 ZO6 exhaust system on my 08 LS3 coup and I love it. Especially now that I had the ZO6 muffler mod done. However, this little clamp will allow it to stay open say 1/4 way and that's going to sound soooo good.
Thanks, Dewman
Thanks, Dewman
Then start the car and drive it around a bit to see if you like the sound. If not, make adjustments in the clamp position for either louder or softer sound until you get it just right. It's amazing.
As a kid, did you ever attach playing cards with a clothes-pin to a bicycle so the spokes make a loud sound when you ride? It's that easy.
Great product.
I totally agree, I installed my clamps last year to enhance my M2W, the improvement in the mild version sound is unbelievable. For me leaving the M2W in wild was too loud, and in mild not loud enough. This is the perfect simple and easy install solution at a very low price! Great product for anyone that has the NPP from a very satisfied customer!
Installed mine yesterday...and I love it! Have been playing with the adjustment to get it just like I like it. Found that about between 1/4 and 1/8 open is perfect for me.
Steve
Steve
Former Vendor
St. Jude Donor '09
The kit comes with 2 custom stainless collars and one extended length Allen wrench. Installation is very simple and fool proof. Can be removed anytime.
1. Remove one allen screw and loosen the other all the way
2. Slip the collar over the actuator rod
3. Align the open screw hole
4. Install the other Allen screw using the provided tool
5. Set the position and tighten both screws
6. Loosen the screws to readjust anytime
The results are amazing I set them to be ¼” open,. Closed at idle you can just tell it’s not the stock exhaust as it has a nice enhanced exhaust tone. The real difference is on the road. Now in the closed setting, the exhaust has a mild but noticeable exhaust note.
Just louder than stock, but not the loud open pipe sound of the system in the full open position. When under moderate acceleration, you now hear the exhaust and any burble or popping is greatly reduced.
Setting it to 3/4” open you can even get some additional sound before it opens over 3000-3500 RPM. I believe this coupled with my Mild2Wild wireless controller give you the best of both worlds. And for those that don’t like the open sound below 3000 RPM, this offers the option of some added sound at idle, and above.
This will not damage the NPP/Z06 actuators since they are closed on vacuum, this kit just makes them stop a little earlier.
The first batch of kits are sold out and more are being built order now for delivery in 5-7 days.
ORDER LINK
Member modshack has done work in this field and commend him for his efforts.
So how loud is a set of stock zo6 mufflers in open mode with headers?
also thinking i should do the muffler mod before i put them on, but to me thats the same thnig as strait pipes, and is going to be TOO nasty with headers and off road X.
and last question, your mild mod (little clamps to keep the valves open a little) does this sound like an exhaust leak? or can you hear anything othert han the sound just get a little more and more the more you keep them open?
Thanks, also do you offer a mild 2 wild control in a box? i am putting this on a 06 ls2
