Low Voltage at Startup
I was wondering if anyone else has ever seen a similar problem I started having. At startup my DIC will read 11.2~11.7 volts while I rest at Idle. Of course my "Service Charging System" then flashes. But then when I begin driving the voltage jumps up to 13.5 ~ 14.0 volts on the DIC. While driving it will read 14.0 steady on the DIC and when I sit at a stop and idle it will drop and jump all over the place (anywhere from 12.8~13.8), but doesn't ever get as low as it does on initial startup.
My major concern is why it is reading so low on the DIC at startup, anyone else ever seen this problem?
I have not heard nor eperienced this problem. Without knowing the year of your Vette or the age of your battery it is difficult to offer much other than to have the dealer check it out.
It's a 2005. I checked the voltage at the battery and at the alternator with the car off it reads normal (12.5 volts). When I first start the car the DIC will read 11 volts right after start-up, then it goes up after sometimes 30 seconds sometimes a few minutes. I haven't had a second set of hands at my house yet to start the car while I sit with the voltmeter under the hood. I'm curious what it will read under the hood with the voltmeter right at startup. Ever since the problem started it's began to struggle a bit at startup, idle dropping etc.
And I do have a Cam and Underdrive pulley, but before everyone starts blaming that, I've had those for awhile and this is a new issue.
Jim
If the under-drive pulley affects the speed of the alternator, then it's most likely due to the under-drive pulley. Some people with tuners change the calibration for the error message to a lower "trip" voltage, and some just turn the feature off altogether.
Does anyone know how much HP is gained by going to an under-drive pulley? I've see a lot of complaints from people with them that complain about system voltage.
