Best way to get wax off trim?
I just bought a '08 C6, and the previous owner (or the dealer) got some wax on the black rubber trim and didn't get it off.
So now it has those white stains on it.
What is the best way to get those stains off?
Moderator
Received 3,584 Likes
Stoner's Trim Cleaner
There are a number of ways to remove wax residue, but for me the easiest way is to wipe with Meguiars #39 Heavy Duty Vinyl Cleaner. It removes the residue effortlessly and leaves the trim looking better than before you waxed.
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'17,'18-'19-'20-'21-'22
A little No. 2 diesel fuel would be the cheapest approach. Similar petroleum solvents are the thinners in most liquid waxes.
Just be careful with alcohol, as it can dry out the plastic over time. If you use alcohol to remove wax, remember to give it a good coat of trim/plastic treatment. Personally, I use Meguiar's Natural Shine.
-Mike
-Mike
Former Vendor
peanut butter does indeed work, then follow up with Poorboys Trim Restorer to make the trim pieces look new for months.
www.autogeek.net
www.autogeek.net
