Doing an interesting mod & need charcoal carpet??
I have decided to put a solid divider between the cab & cargo area. It will have a little glass in it for the rear view window. I will be adding speakers behind the seats as well.
I need to know where I can get the charcoal carpet to cover it with. Is there a place that just sells it by the square foot or something? 4 foot by 4 foot should do it.
What you want is Truvette T912 Ebony. I got samples from
http://qualitycarinterior.com/automo...nch-width.html. and it is a perfect match. You can get the backing in either rigid or latex which is more bendable.
It is not cheap at 60-70 a yard but it is a perfect match. Just get a free sample before you jump in.
I hope this helps.
I hope this helps.
You may also want to check this place. I bought carpet from them to cover a box I made. Very good prices.
http://www.parts-express.com/home.cf...TOKEN=44508648
You can also try here, but I think they only sell the hard backed carpet and not the latex backed.
http://www.accmats.com
