sway bar install question
Just installed the z51 bars on my 08 F55. I ordered the kit from Fichtner Chevy, prompt good service. The kit included 2 bars and 4 rubber bushings. The back 2 bushings were in a bag that looked to have a lubricant on the rubber. The front bushings were in a bag but were dry with no lubricant. The question, should there be a lubricant on the front bushings, and if so what type?
Haven't driven it enough to comment on the handling but the ride does seem stiffer for whatever reason.
My understanding is that only the polyurethane bushings need lube because they are very solid. If these are the black rubber bushings, then I don't think it is required because the rubber moves with the turn of the bar and absorbs the movement within the rubber itself. With the hard poly bushings, the bar actually turns against the surface of the bushing, so lube is needed.
I have a Z51 and dropped the rear sway bar (center bushings only) for an exhaust install. I believe there was no sign of lube nor did I add lube. I would agree that the rubber bushings don't need lube.
I know this doesn't answer your question but now that your a pro at changing your sways you might want to add poly bushings instead of stock. They compress less and add to the performance of the new sways. Very cheap mod.
PS they come with Lub
Don't use petro based grease on the rubber bushings. It will degrade the rubber. Use a silicone based lube if you want to lube the bushings. And, by the way,,, Z51 bars on F55,,,
My GM OEM bushing (both front and back) came prelubed in bags from GM Parts.
PS: Now you have a "Z55" or even better, a "Baby ZR1", please NO flames.
Thanks for the replies. This afternoon I loosened up all the bushings with weight on the wheels and retightened to make sure they were not preloaded from installing them with on the lift. I was thinking with the clamp up on the front bushings there may be no rotation just rubber twisting. It probably did not do a thing but it made me feel better.
I did check the old bushings and the front ones seemed dry but had worked into a smooth slick inner surface. The rears had a tacky substance that felt more like glue than lube.
