2 post legs low enuf for a C6?
anyone have a 2 post lift and have trouble getting the lift legs under the C6? I have lowered my car and wondering if i will need to have a couple of boards to drive onto to get it high enuf to kick the lift legs under the car. thxs, paul
you will most likely need boards. Rotary lifts are some of the lowest lifts on the market and they are barley low enough to go under a non lowered C6
i am looking to get a bend pak, it shows 4 inches as the height of the feet. I meant to check mine,,,,,,, you fella's are probably right, i will need a board to drive up on. Thanks, paul
I stack 3 pieces of 3/4" plywood in order to use my 2 post lift (SnapOn Wheeltronics lift). I did not want to recess my lift into the floor.
I find it easier to drive the C6 into lifting position, and using a jack, lift the front/rear enough to slip the small plywood sheets under the tires.
The lift arms have built in puck attachments.
My C6 is not lowered.
M.......
M.......
