Frustrated and sad!
Frustrated and sad!
Took the vette in for the creaking roof fix and a defective cruise control system. Based on the origina diagnostics the entire job was to take no more than 90 minutes, maybe 2 hours. Well 9 hours later my vette is still in the shop and the lower dash panels are all off with a maze of wiring hanging out everywhere. Turns out the module and switch they suspected was not the issue. Instead they have found that voltage is not getting to the system. The tech has spent hours now trying to isolate the faulty wire and/or harness.
It is very concerning when you see the car taken apart like that. You begin to imagine everything that will now go wrong after the repair. Endless squeeks and rattle from below and behind the panels comes to mind as well as what else may no fail because it was messed with or improperly re-assembled.
I know its just paranoia and all should be well in the end, I hope, but one cannot help but to wonder and worry.
On the bright side they gave me a loaner to use. The ZR1 I am riding in right now is sweet! NOT!
The gave me a Cobalt sh*t box. I can really understand why GM is loosing their asses to the foreign manufacturers in the small econo car space. This thing is the cheapest, crappiest thing I have ever seen or riden in. IMHO.
Weel at least I have a loaner, right? Toyota and Nissan, etc don't do that so I shouldn't complain.
Well hopefully I will get a call soon that my car is ready.
I've always thought the same thing about creating noises by taking too much apart.
Tough to judge a car when it's a loaner or rental that gets beat up. My cousin has a Cobalt and for the money it's a good car.
The Toyota dealer near me does provide a loaner car on the 30,000 mile services. The car they loaned me, a Yaris, makes the Cobalt look like a Cadillac. I was fearing for my life driving that thing in traffic.
lucky f**k
We got a twice used Neon. Used and used up.
Well, at least it looks like they are making an honest attempt to fix the problem corectly, Wiring issues can be really difficult to trace when the cause of the problem is not obvious like a broken wire or a burnt contact. I have to disagree about the Cobalt though, sure the base model is very lean on features but that does not make it bad, that just makes it low priced. JMHO. Good luck with the repairs !!!!
Nothing I can add except good luck!
Wrong...I've gotten a loaner every time I get any work done at my Toyota dealer. So does my daughter and it's a different Toyota dealer. These dealers also both happen to be GM dealers too.
CF Senior Member
I take it you're not used to working on cars...things get taken apart and put back together again. That's how it works. Quite often, things don't go as you initially plan. It's no big deal...you are being paranoid. Be pleased with their diligence…they’re trying to fix the problem.
Good Lord, GM gives you a loaner car to use and all you do is complain about it. A BMW or even a Corvette its not but for what it is I don't think a Cobalt is all that bad. If the Cobalt is that distasteful to you...take it back!
I had a 1998 Z24 Caviler it had 110,000 and I sold it and bought a 2003 Caviler with 32,000 miles on it (not sure what trim code) but its loaded XM radio, on Star (not activated) fancy fog lights (factory) etc.. I just got home from a 500 mile trip and averaged 26 mpg doing 80 mph most of the way...
The radio sounds great.. only complaint is a few squeaks in the front end... but for $5200 on a 32,000 mile car I can go wrong...
However I'll still take my C6 over the Caviler
