Top Speed by Gear ??
Goon Squad King of Battle
St. Jude Donor '08-'09-'10-'11-'12-'13x3- '14-'15-'16-'17-'18-'19-'20-'21-'22-'23
Does anyone have the top speed by gear for the Z51? I'd like this info without actually doing the tests myself.
Thanks,
Thanks,
This has been posted here in the recent past. You can use one of the below converters, the trans gear ratios and figure out what your looking for.......
http://www.csgnetwork.com/automotiveconverters.html
Moderator
Received 3,570 Likes
Buzz, you can try this one: http://mysite.verizon.net/foofoo2/c6/index.html
CF Senior Member
Here's an approximate guide:
ENGINE<------Vehicle_Speed------------>
RPM...1ST...2ND...3RD...4TH...5TH...6TH
1000....8....13....20....27....37....47
1500...12....20....31....41....55....70
2000...16....26....41....43....73....93
2500...20....33....51....68....92...116
3000...23....40....61....81...110...140
3500...27....46....71....95...128...163
4000...31....53....82...109...147...186
4500...35....60....92...122...165...186
5000...39....66...102...136...184...186
5500...43....73...112...149...186...186
Hmmm... these two charts are quite different.
The link that johnodrake posted will let you enter the right chart by simply clicking on the right link for the tranny & rear axle ratio you're talking about.
Wayne's chart seems to be an approximation for most manual C6 trannies.
Here's an update with the tire size calculator built in:
http://bolero.csustan.edu/C6/C6_Gears.xls
--Dan
Glad you like it.
--Dan
--Dan
BJK
