CAGS smart fuse
CAGS smart fuse
Just a heads-up for anyone thinking about using one of the smart fuses out there available from some vendors to defeat the CAGS; if you have an '08 it will defeat the CAGS, but it will also throw a CAGS code and light the CEL. I tried one last Saturday in place of the regular in-line unit at the solenoid (which worked fine) just to see if it would be as effective and easier to remove for dealer visits. As far as '08s are concerned, at least my '08, it is not a good solution, stay with the tried and true in-line CAGS defeat systems. I had the car serviced later the same day and the dealer had a very hard time getting the code to clear for some reason.
I have an 08. Bought the Smart fuse and blew it myself. Replaced the stock fuse and no problems at all. No codes and it works fine. I'm not sure where your problem was but maybe you had a bad Smart fuse. If the Smart fuse isn't working correctly or you just remove the fuse then it will throw a code but I have been running it for about two months with no issues.
You know, I'm not sure where the problem was either. The unit appeared to work fine for about 15 miles of driving. I stopped at the market and when the car re-started it threw the code. I was a half-mile from the dealer so rolled in to diagnose the light (after first stopping the engine to remove the fuse and replace with the standard 10a).
The dealer diagnosed the light was a CAGS code and then had a devil of a time resetting the code...would not clear out, taking five tries with the GM machine. They scoured the car top to bottom looking for a problem and found none so chalked it up to an electrical gremlin that awoke after the long winter nap.
Bad fuse? Maybe, don't know, but I probably won't try a fuse again just in case there is some potential quirk in my '08 that hates the taste of smart fuses. Will just fall back on the under-car harness to the solenoid which worked A-OK for a year with zero trouble and 100% perfect performance. All I wanted was an easier way to return to stock for those, hopefully, infrequent dealer visits.
Thanks for your feedback.
Same here
Banned Scam/Spammer
The fuses will exhibit different current flow depending on the resistor/LED circuit each has; brand and values seem to differ based on the posts I've read. Maybe the current flow through one is enough to set off a code, and not enough with another?
No code on my '08 with a self blown smart fuse however one time it still forced me to shift from 1 to 4. Only happened once, but that was with the smart fuse installed. Maybe this mod only works if the resistance of the blown fuse is just right.
I'm not so sure about that swiftrider08,I had a buddy of mine with a 96 gs back in the day with cags defeat device installed had a transmission failure on the road and had the car towed directly to dealer.When the dealer put the car up on the rack and saw the cags solenoid disconnected with the resistor in harness,they said no to the warranty the cost!! 6k at the time for the tranny to be rebuilt.
my 08 did the same thing blown the fuse installed and service light came on, replaced normal fuse and all is well. so i decided to check the resistance of the resistor and it showed opened, i think the way you blow the fuse could also open the resistor so check your blown fuse with a meter and see what you get.
Well, after all the feedback I did some checking. The original vendor-supplied fuse is OK, the LED lights up when powered from either side. I noticed, however, that the LED is extremely faint, almost invisible. So I went to O'Reilly's and bought a 2-pack of Littel brand 10a smart fuses for $3. I blew the fuse and checked it for LED function. Both directions it glowed very bright and strong. Put in the new fuse and so far it seems to be working fine, CAGS light comes on but CAGS is defeated. Drove the car around all afternoon starting and stopping the engine several times.
I think the car's computer system checks all the circuits and needs a certain minimum current flow for the test to work properly. Apparently the vendor-supplied fuse is not able to pass the proper amount of current to pass the test so the computer lights the CEL. Anyone having a similar problem might want to look into using the Littel brand of smart fuse.
Thanks to all,
NS
Thanks to all,
NS
Thanks to all,
NS
Thanks to all,
NS
Just FYI I own an 09 built last month and I put in the blown smart fuse immediately.
The diagram to follow in the owners manual was a little off as to what fuse did what but I switched it out anyhow with what I thought was the correct location. The light on the dash comes on but the 1-4 is defeated. Works like a charm, so far.
Guys,help me out here.I bought the CAGs eliminator from MidAmerica.I have'nt installed it yet.Has anyone had any problems as far as throwing codes,mine is an 09? I think 08 and 09 are the same in that area.
If you are using the in-line harness at the transmission solenoid everything should be A-OK with no codes, just way less aggravation when shifting. If you want to try the fuse method you will probably be OK if the fuse passes enough current to fool the computer when it checks the circuit continuity. Get a pack of the Littel brand smart fuses at O'Reilly's auto parts and pop one. Install it and see if it works for you. If it does not, try another brand or use the harness.
