Apply Rejex: what to remove old wax. Dawn? Simple Green?
I'm going to REJEX my C6, but first want to remove all the wax. REJEX said to use Dawn, but will that really remove all the wax? Would Simple Green be too strong? Thanks!
Zaino recommends Dawn dishwashing detergent for it's alkalinity as Shineshop mentions above. Zaino states this right in their instruction sheet.
See attached pic below. Look at step 2. in the process.
F.Y.I.
F.Y.I.
Received 1,350 Likes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'22-'23
I used Dawn and Ice liquid clay to remove everything before the Zaino went on. I sprayed the Dawn/water mix on and applied the liquid clay with it. I know many will bad mouth the Ice liquid, but it worked great for this as well as on a friends black C6 to get the finish clean and slick. Much easier than clay, maybe not as effective but still good enough depending on what you want to accomplish.
I have used Dawn for several years. Seems to work good with no ill affects that I can tell. I just use it about two times a year. After washing then clay bar, polish, glaze and final wax.
1 Post
St. Jude Donor '06
Go here for everything you ever wanted to know about Rejex and more......
http://www.rejex.com/rejex.html
