Larger or just Wider contact patch?
A taller narrower tire could have the same rubber on the road as a shorter wider tire but that wasn't the OP's statement.
The 10 1/2' drag classification doesn't say anything about diameter, just a limit of 10.5" wide. If somebody could build a tire 52" tall (and a car with gears to handle it) the car would have a much larger (longer)footprint than a 26" 10.5" wide tire.
Bigger diameter gives a longer footprint, wider gives a wider footprint. A 26.7" tall, 345mm wide tire puts more rubber on the road than a 26.7" tall, 285mm tire. The load my be different but the footprint does get larger with a wider tire.
Physics and common sense do go together. My little brother was a Physics Professor @ Brandeis and one of his ways of "solving" a problem or looking for a solution was to apply extremes. Given the OP's criteria the posted statement is false. There is no mention of the direction or type of the load, type of tire, inflation pressure, etc.
Its all about "pounds per square inch."
If two tires, one wider than the other, are at the same inflation pressure, they will support the same amount of vehicle weight, with the same amount of contact to the ground.
If the car weighs 4000lbs, and each corner is the same weight, then each tire supports 1000 lbs. If the inflation pressure is 33.3 psi, then each tire would need a support base (contact patch) of 30 square inches to equal the 1000lb weight.
The "thirty" inches of contact patch can be 6 inches wide and 5 inches long (skinny tire), or 10 inches wide and three inches long (wider tire).
Either way, there is 1000 pounds excerted on the tire, and in response the tire is pushing back a 33.3 pounds per square inch, requiring 30 square inches of support base to do the job.
Class is OVER
Class is OVER
That said, I did not include dynamic issues, nor did I include the variables of tire construction or technology. The fact is: that with given pressure and given load-weight, footprint size (square inches) is identical in a static state, regardless of tire width.
HOWEVER, dynamics do play a roll, as do tire characteristics. As a result, my post is even better proven.
Top Fuel Dragsters utilize tires that accommodate both desires. They use low pressures that present a BIG footprint (read contact patch) at rest and at initial launch, then only to grow in circumference while reducing in width producing a narrower and longer contact patch that accentuates high-speed acceleration, and higher overall gearing. When these cars do have side-slip, they most always go out of control.
Road-Racers embrace the virtues of wide tires and the "wider than longer" contact patch. This type of patch supports lateral loads better than the opposite, therefore allowing for higher cornering speeds, i.e., faster lap times. They optimize tire width to aide in lateral grip and straight-line breaking. Too wide = NOT GOOD while too narrow = NOT GOOD. In addition to optimized tire size, they also optimize tire pressure to ensure adequate contact-patch to successfully match the challenge.
Physics is physics, and traction is inherently separate from the scientific term of friction. Track tires are most always wider, and snow tires are most always narrower.
Okay, the dissertation is over.....WIDER always looks BETTER
Allegro, let's take your equation from above: 1000 lbs / 33.3 psi = 30 sq in. Now let's apply it to a run flat that is holding up 1000 lbs at, say, zero or 1 psig. What's your contact patch then? Tires don't behave ideally like you suggest. Also, why doesn't the actual data mentioned in FortMorganAl's link above support your case?
I guess I will just respectfully bow out.
