Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Corvette General Discussion
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
General C6 Corvette Discussion not covered in Tech Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-21-2009, 09:28 PM   #1
Finster07
CF Senior Member
Finster07's Avatar
Default Mobil 1 vs Mobil 1 Extended Life
Whats the difference?
I just read a thread about Advanced Auto Parts having a deal for 5 qts Mobil 1 5-30 and the Mobil 1 filter for $29. Not bad. I called and they told me that's for either the regular or extended life oil.
Finster07 is offline   Reply With Quote
Old 03-21-2009, 09:46 PM   #2
TEXHAWK0
CF Senior Member
TEXHAWK0's Avatar
Extended Service has extra additives to extend the period between changes. You can read exactly how much on the Mobil 1 website.
TEXHAWK0 is offline   Reply With Quote
Old 03-21-2009, 09:47 PM   #3
C6NRED
CF Senior Member
C6NRED's Avatar
At one point, the Extended Life was not yet certified for use in the Corvette.....is it now?
C6NRED is offline   Reply With Quote
Old 03-21-2009, 09:51 PM   #4
AORoads
CF Senior Member
AORoads's Avatar
Yes, seems like quite a good oil, and it doesn't meet that GM spec for Corvettes. (from here: http://www.mobil.com/USA-English/Lub...erformance.asp)
"Mobil 1 Extended Performance Pdf
Fully Synthetic Engine Oil Print View
Product Description Features and Benefits Applications Specifications and Approvals Typical Properties Health and Safety
Product Description
Mobil 1 Extended Performance 5W-20, 5W-30,10W-30, and 15W-50 are advanced performance synthetic engine oils designed to provide protection and performance at extended oil change intervals of up to 15,000 miles or 1 year, whichever comes first. Mobil 1 Extended Performance features extra performance additive that helps to provide outstanding protection during today's longer oil change intervals.
Mobil 1 Extended Performance 5W-20, 5W-30, 10W-30 and 15W-50 are made with a proprietary blend of high performance synthetic basestocks fortified with an advanced additive system, designed especially to deliver performance and protection during longer service intervals. Mobil 1 Extended Performance oils are uniquely designed to provide outstanding levels of performance, cleaning power and engine protection, even during longer oil change intervals. Mobil 1 Extended Performance oils are available in a wide range of viscosities. The 5W-20 and 5W-30 viscosities are recommended viscosity grades for newer vehicles. The 10W-30 viscosity provides excellent all-season performance and protection. Mobil 1 Extended Performance 15W-50 is formulated to provide outstanding engine protection for high performance engines and for consumers who want a higher viscosity oil and higher anti-wear performance ( ZDDP) than typically required by modern vehicles.
Features
Advantages and Potential Benefits
Fully synthetic formula with Advanced SuperSyn System Prevents deposits and sludge build-up to enable long engine life.Excellent overall lubrication and wear protection performance under all operating conditions.
Extra levels of performance additives Provides outstanding engine protection at oil change intervals of up to 15,000 miles or 1 year, whichever comes first
Outstanding thermal and oxidation stability Exceptional control of oil breakdown ; Helps maintain stable oil viscosity
Provides exceptional engine protection Helps maintain long engine life and is compatible with engine seals.
Excellent low temperature capabilities Quick cold weather starting for fast protection and extended engine life. Provides less stress on your starting system
Applications
Mobil 1 Extended Performance engine oils are recommended for all types of modern vehicles, including high-performance turbo-charged, supercharged gasoline multi-valve fuel injected engines found in passenger cars, SUVs, light vans and trucks.
* Mobil 1 Extended Performance oils provide guaranteed protection of critical engine parts for 15,000 miles or one year, whichever comes first. Excluded service includes: commercial and racing applications; frequent towing or hauling; extremely dusty or dirty conditions; or excessive idling.
* If your vehicle is covered by a warranty, follow the vehicle's oil life sensor or the oil change interval recommended in your owner's manual. Proper maintenance practices, including frequently checking the oil level to ensure that the appropriate amount of oil is present, are required to ensure effective performance.
* New Mobil 1 Extended Performance 5W-20 delivers the viscosity recommended for most Ford and Honda vehilces since model year 2001. It is also the viscosity recommended for many Chryslers, beginning with model year 2005.
Back to Top
Mobil 1 Extended Performance meets or exceeds the following industry specifications:
5W-30
10W-30
15W-50
5W-20
ILSAC GF-4 GF-4 GF-4
API SM,SL,SJ,SH/CF SM,SL,SJ,SH/CF SM,SL,SJ,SH/CF SM,SL,SJ,SH/CF
ACEA A1,B1,A5,B5 A1,B1,A5,B5 A1,B1"
AORoads is offline   Reply With Quote
Old 03-21-2009, 09:58 PM   #5
VETTE IV
CF Senior Member
Mobil 1 Extended Performance oil does not meet the Corvette spec GM4718M per
http://www.mobiloil.com/USA-English/...nce_5W-30.aspx
Don’t use it
VETTE IV is offline   Reply With Quote
Old 03-21-2009, 10:00 PM   #6
VET4LES
CF Senior Member
VET4LES's Avatar
Donít use it
VET4LES is offline   Reply With Quote
Old 03-21-2009, 10:02 PM   #7
rjwoerheide
CF Senior Member
rjwoerheide's Avatar
Righto. As already stated, stick with Mobil 1.
rjwoerheide is offline   Reply With Quote
Old 03-21-2009, 10:07 PM   #8
redjetty
CF Senior Member
redjetty's Avatar
Donít use it
correct you are!!
redjetty is offline   Reply With Quote
Old 03-21-2009, 10:25 PM   #9
RRVettes
CF Senior Member
Support Corvetteforum!
RRVettes's Avatar
Good post. At first glance, I would have thought it would meet GM spec.
RRVettes is offline   Reply With Quote
Old 03-21-2009, 10:39 PM   #10
cclive
CF Senior Member
cclive's Avatar
And as of April first, with the Mobil One rebate certificate, 5 quarts will cost $16 at WalMart...leaves lots of money for any overpriced filter anyone would like!
cclive is offline   Reply With Quote
Old 03-22-2009, 01:04 AM   #11
Finster07
CF Senior Member
Finster07's Avatar
Quote:
Got it. Buy the regular stuff for only $16 at Walmart.
Old 03-22-2009, 08:54 AM   #12
Red Rochester
CF Senior Member
Red Rochester's Avatar
Product Description
Features
Applications
Back to Top
5W-30
10W-30
15W-50
5W-20
That's good just filled her up yesterday.
Red Rochester is offline   Reply With Quote
Old 03-22-2009, 10:21 AM   #13
JERGENSEN LS3
CF Senior Member
JERGENSEN LS3's Avatar
Location: New Jersey - National Corvette Museum Member '08, '09, '10, '11, '12
Good to know.....Thanks
JERGENSEN LS3 is offline   Reply With Quote
Old 04-17-2009, 12:11 PM   #14
mike100
CF Senior Member
mike100's Avatar
Strange though that GM's own CD that comes with the corvette owners manual shows a gold capped bottle of Mobil-1 sitting on top of the LS3 in the maintenance section of the video when talking about oil changes.
I don't think GM even knows or isn't going to officially say it is the better oil. If anything, they are not going to encourage people to try to go for 15k mile intervals, if I had to guess.
mike100 is offline   Reply With Quote
Old 04-17-2009, 12:31 PM   #15
GotVett?
CF Senior Member
GotVett?'s Avatar
Donít use it
That's what I was told when I asked waay back.
GotVett? is offline   Reply With Quote
Old 04-17-2009, 05:03 PM   #16
zich6
CF Senior Member
St. Jude Donor '08-'09
zich6's Avatar
Since mine isn't a DD, I end up changing at 1 year way before 5K, so it's not worth it for me.
zich6 is offline   Reply With Quote
Old 04-17-2009, 05:24 PM   #17
USAF-Vette
CF Senior Member
USAF-Vette's Avatar
Guys,
I have seen countless oil analysis on Mobil products. The current oil standard is SM. The introduction of the SM standard mandated a reduction in Zinc and Phosphorus in the oil to around 800 parts per million or so. The previous standard was SL, which capped Z and P at ~ 1000ppm. By the way, SL Mobil Synthetic did meet 4718M. Anyway, it is my opinion that Mobil 1 Extended Life is nothing more than the old SL formula with a new label. I base this on oil analysis from the previous "regular" Mobil 1 Supersyn and the "new" Extended Life stuff......the numbers are identical.
Stuff like this happens all the time. Some of these (if not all) certifications cost money. Sometimes it's just cheaper not to get it, even if the oil meets and even exceeds the standard.
Another good example is Mobil 1 Truck and SUV 5W-40. It is exactly the same as the Famous Delvac 1, 5W-40 Gas/Diesel engine oil. Yet, under the Delvac label, the oil costs some 15-20% more a quart.
Anyway, my point is, the Extended Life stuff will meet and exceed 4718. I would use it without hesitation.....not for 15k miles though.
Rick
__________________
2009 Corvette 1LT, 6-speed manual
- Airaid intake
- Home ported throttle body
- Loudmouth II exhaust
- Predator "canned" tune
- Bilstein HD Shocks
USAF-Vette is offline   Reply With Quote
Old 04-19-2009, 05:48 AM   #18
ssv3
CF Senior Member
ssv3's Avatar
Quote:
Originally Posted by USAF-Vette View Post
Guys,
Rick
Absolutely agree with you and as a matter of fact just put in the Mobil1 EP two days ago. Not waiting for 15k to change my oil.
ssv3 is offline   Reply With Quote
Old 04-19-2009, 06:16 AM   #19
gota07
CF Senior Member
Cruise-In VIII Veteran
gota07's Avatar
I've currently got the Mobil 1 Exteneded oil in my Vette. The last time I was due for a change, I couldn't find the regular Mobil 1 and went ahead and got the extended oil just to get the change done.
I'll change it out when the oil life monitor indicates it's time for it, and will look for the regular Mobil 1 for my next fill.
gota07 is offline   Reply With Quote
Old 04-19-2009, 08:08 AM   #20
Walt White Coupe
CF Senior Member
Walt White Coupe's Avatar
Guys,
Rick
Walt White Coupe is offline   Reply With Quote
Reload this Page Mobil 1 vs Mobil 1 Extended Life
Tags
10w30, 530, 5w20, bad, c6, change, corvette, extended, interval, ls3, mobil, mobile, oil, performance, require, turbos, vs
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
AMSOIL vs Mobil 1 C66 Racing C5 Tech 48 10-26-2013 04:49 AM
15000 mile oil ICULUKN-C5 C5 Tech 74 03-17-2005 10:21 PM
AMSOIL vs Mobil 1 C66 Racing C6 Tech/Performance 72 09-18-2004 06:35 PM
AMSOIL vs Mobil 1 C66 Racing C3 Tech/Performance 33 07-19-2004 06:50 PM
AMSOIL vs Mobil 1 C66 Racing C1 & C2 Corvettes 14 07-19-2004 07:56 AM
AMSOIL vs Mobil 1 C66 Racing C4 Tech/Performance 30 07-18-2004 10:34 PM
Do new Z06's need an oil change after the initial 500-1000 miles break-in period? 427L C5 Z06 Discussion 39 02-04-2003 05:42 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
