Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Corvette General Discussion
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
General C6 Corvette Discussion not covered in Tech Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-17-2009, 09:20 PM   #1
Sinister Evil
CF Senior Member
Sinister Evil's Avatar
Default Check engine light ON
2006 C6 Z51. and after 65,000 miles my check engine light came on. I have no serious mods on the car anymore except for B&B exhaust and Vararam intake. What should I do besides take it to a mechanic with a OBD reader? Could it be a bad sensor. I keep up with all the maintenance. Suggestions? Guidance? What to do?
Sinister Evil is offline   Reply With Quote
Old 03-17-2009, 09:28 PM   #2
RicK T
CF Senior Member
RicK T's Avatar
If you have OnStar you could ask for a diagnosis from the code. If not, then someone with a code reader is the only option. I think Autozone might do free code reading if there is one near you. Or there is always the dealer. Good luck, let us know what it is.
RicK T is offline   Reply With Quote
Old 03-17-2009, 09:30 PM   #3
RedRider1
CF Senior Member
RedRider1's Avatar
Auto Zone has a scanner that they will let you use for free. This will also reset the light. You can also reset the Check engine light be disconnecting the positive battery cable. Leave it disconnected for around 15 minutes and this will also reset the light. You will have to fix your windows if you disconnect your battery also.
RedRider1 is offline   Reply With Quote
Old 03-17-2009, 09:35 PM   #4
jeepers10246
CF Senior Member
jeepers10246's Avatar
I also have a 2006 Z51- 30'000 miles Just had a check engine light.
It was a Evaporation canister for the Emission system. Fixed -Light is gone.
No reason given for it to fail. Took it to the Dealer where I bought it
jeepers10246 is offline   Reply With Quote
Old 03-17-2009, 10:03 PM   #5
Sinister Evil
CF Senior Member
I bought a $20 OBD II and it threw one code. It is the throttle position 1 performance code P0121. What to do? When I turned the car on again the check engine light was NOT ON but when I plugged in the OBD II it threw that one code P0121.
Suggestions? What do I have to fix? I don't want to erase the code until I address the problem.
Old 03-17-2009, 10:11 PM   #6
RicK T
CF Senior Member
RicK T's Avatar
Here is some reading material but I'm thinking a trip to the dealer is at hand:
http://www.obd-codes.com/p0121
Old 03-18-2009, 09:23 PM   #7
Sinister Evil
CF Senior Member
I never cleared the code, but the check engine light hasn't come on. Thanks RickT. I'm off to the dealer on Saturday morning just to make sure....since my car is out of warranty I'm sure they are going to try to make some $$ at the dealer.
Old 03-18-2009, 09:36 PM   #8
RicK T
CF Senior Member
RicK T's Avatar
Take a dozen bagels or donuts, it can make a difference especially on a Saturday. Good luck.
Old 03-18-2009, 09:44 PM   #9
shopdog
CF Senior Member
On the throttle body there are two variable resistors which report throttle blade angle. They are wired so that one reads 0 ohms at full closed and maximum ohms when full open while the other reads 0 ohms at full open and maximum at full closed. This is to give a sanity cross check to the ECM in case one fails shorted or open, and allows the car to continue to be drivable. These variable resistor sensors, called TPS (Throttle Position Sensor) are replaceable parts, available at most auto parts stores for a few dollars. It isn't necessary to replace the entire throttle body.
These are wear parts. Internally, there is an arm with a conductive brush that moves over a resistive substrate. With repetitive use, the brush wears down and the resistive substrate wears away. Eventually, the contact becomes noisy, intermittant, or fails entirely. The ECM throws the code when this happens. Sometimes you can extend the life of the sensor by using a product called Quietrol to clean and lubricate the resistive substrate. But that's a temporary fix at best. The correct fix is to replace the TPS.
shopdog is offline   Reply With Quote
Old 03-18-2009, 09:48 PM   #10
shopdog
CF Senior Member
Quote:
Well, it'll reset the light until you hook the battery back up anyway.
This old wives' tale just will not die, will it? There are a number of conditions which will reset a CEL, depending on which particular code caused it. Disconnecting the battery isn't one of them.
Old 03-18-2009, 09:53 PM   #11
KenHorse
Obama Must Go
St. Jude Donor '11-'12-'13
Support Corvetteforum!
KenHorse's Avatar
Location: Aurora, OR by way of Maui..... The Obama Regime is The Most Dishonest, Corrupt And Criminal In US History©
Did you recently add Z51 badges?
There are some who believe the addition of them will throw a code
KenHorse is online now   Reply With Quote
Old 03-19-2009, 11:27 AM   #12
Brutus 08 Coupe
CF Senior Member
Brutus 08 Coupe's Avatar
First: Congrats on getting great use out of your car. 20,000 miles/year = . Second: Run her to Autozone or the dealer to retrieve the code. You have no choice but to find out what you're up against...
Brutus 08 Coupe is offline   Reply With Quote
Old 03-19-2009, 11:34 AM   #13
freyke
CF Senior Member
freyke's Avatar
Here's my story -
Went to my local friendly Chevrolet Dealer (R.K.) here in Virginia Beach and told them CEL (Check Engine Light) was on. I asked the service writer to read the code. He was more than happy to; we plugged his OBDII scanner in and we were rewarded with "P0174" "Bank 2 System Too Lean."
Click the image to open in full size.
This appears to be a good thing and is likely caused by a random hiccup due to my CAI and Cat-Back exhaust. We decided to clear the fault via the scanner and see if it returns. I somehow doubt it will (soon anyway). So in light of this I just went out and purchased a basic OBDII scanner with read and erase capability (cheap - actron PocketScan Plus $59.00). This way I can just clear it without driving all over town next time.
freyke is offline   Reply With Quote
Old 03-19-2009, 11:36 AM   #14
HawaiiC6
CF Senior Member
HawaiiC6's Avatar
My advise listen to ShopDogs advise, with the amount of miles on your car you are due sooner or later to change out your TPS.
__________________
Aloha
2006 Black/Ebony C6, A6, 3LT, Z51
Comp Cam XR275HR
Stock Heads w/Comp Cams RPM Kit
Yella Terra 1.8 Roller Rockers
160 thermostat
Taylor wires
Vararam CAI,
Vararam Throttle Body Spacer
VMax Motorsports Ported and Polished Throttle Body
VMax Motorsports Ported Intake Manifold
CCA Oil Catch Can
Predator Modified Tune
Kooks 1 7/8" LT with Jet Hot Coating, Kooks Off Road 3" X-Pipes
Borla Stingers
HawaiiC6 is offline   Reply With Quote
Old 05-02-2009, 12:26 PM   #15
Sinister Evil
CF Senior Member
yep!! Thank you all for advising me on the TPS. Where can I get tps sensors and how do I replace them? Are they near/inside the throttle body?
Old 05-02-2009, 12:41 PM   #16
not08crmanymore
CF Senior Member
not08crmanymore's Avatar
My CEL just came on last week and it was a P0171 + P0174 code.To much air in or something.The AUTO ZONE scanner could not turn the light off,the GM one at the dealer did. Check your gas cap and add dry gas in case you got a batch of bad gas somewhere which would set the light off.
not08crmanymore is offline   Reply With Quote
Old 07-02-2010, 07:18 PM   #17
Sinister Evil
CF Senior Member
Fixed!! I replaced the gas pedal and the CEL was gone after two starts. Then it came back on after about 3 months.......I bought a new TB with TPS and DONE!! No CEL for 5 months. If you throw enough $$ at these cars they run great!!!! I luv my 'vette!!
Old 07-02-2010, 07:26 PM   #18
dpigguy
CF Senior Member
dpigguy's Avatar
Quote:
your CEL is likely due to the MAF sensor mis-reading the airflow entering the engine. had similar issues early on. using metal a/c tape, taped off the holes in the bumper support in front of the engine compartment as well as the seam where the front fascia meets the trim at the bottom front of the air box. no more issues and that was 3 years and 25k miles ago.
dpigguy is offline   Reply With Quote
Old 07-02-2010, 07:33 PM   #19
not08crmanymore
CF Senior Member
I was thinking and wondering if I could put some duct tape over that area.I had my light on before I heard about the disruption of air flow because of the design.Now there's a TSB on that code!
Old 07-02-2010, 07:42 PM   #20
dpigguy
CF Senior Member
dpigguy's Avatar
BG had me tape mine up and the CEL issue went away. Here's a picture of the area you need to address:
Reload this Page Check engine light ON
Tags
2009, appears, check, chevy, code, corvette, engine, ii, light, nightmare, obd, p0121, quietrol, scanner, stays, turn
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Check Engine Light on... Doo C5 General 13 11-10-2004 10:11 AM
[1985/A4] Check Engine Light On And Off j3studio C4 Tech/Performance 20 08-18-2004 06:39 PM
Check Engine Light on 04 Z06 JoeyNigs C5 Z06 Discussion 16 10-20-2003 12:25 AM
Check Engine Light On New ATI! scvett C5 Forced Induction/Nitrous 10 09-12-2003 04:33 PM
Check Engine light on and dealer wants $1400?? MatthewC C5 Tech 30 01-27-2003 04:51 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
