C6 Oil Change DIY
C6 Oil Change DIY
I know that this is run of the mill for most. I also realize that it may not be intuitive for everyone. I did an oil change on my Corvette this morning and I figured that I'd just go ahead an document the process for anyone that could use it. Sometimes having pictures along with a description can make a job go that much smoother. I also recall that there is another very good tutorial on the web written by Bugman but I wanted to do this for my website Tech Tips section and thought that I would share with the forum in the process. I have attached the DIY in pdf format below. Also please realize that his procedure is appropriate for coupes and convertibles but does not apply to the Z06. The procedure for changing the oil with the Z06 dry sump system is considerably different. It is also worth noting that my C6 is a 2005 so things under the motor on the oil pan may not look exactly as pictured but it will get you started in the right direction.
Enjoy,
Paul
Enjoy,
Paul
That's a great write-up!
One thing I have tended to do is to raise the passenger side up a bit more when the oil is draining. I think this helps to better facilitate the draining.
What about resetting the oil life timer?
While the display is revealing the % of oil life remaining, hit the RESET button and hold down until the display resets to 100% (5 to 10 seconds).
Ugh, I can't believe that I forgot to add that. Be right back with a correction.
O.k. The document above is corrected to include the process for resetting the oil life monitor. Thanks for the catch.
Run of the mill or not I think it's great. I wish more people documented installs/maintenance/mods etc.. I enjoy looking at them and it helps more people than you think. I did it for GCA splashguards which is really run of the mill but got a lot of good feedback from it. Great job. Thanks
Received 1,919 Likes
nicely done.
I am sure lots of folks would like to change their own oil, but have no way to figure out how. Been doing my own on multiple cars for 40 years.
I suspect that you may get lots of comments on tips and ideas how to do easier, better, etc.
I have one editorial comment: blocking a wheel is chocking not chalking. Do with that comment what you want.
One tech comment - I like your idea of turning the ramp around for access - adding that tip to my routine next time. That's the only major difference between your way and mine (although I use a wide mouth drip catch pan, plus I have a metal pan with a 1/2" lip, about 3' x 4' that I use under cars during repairs, vice cardboard - really helps when doing messier jobs such as trannies, etc.
P.S. Where is Alvaton? (grew up in KY back in teh day)
I debated for a few years because it was a close fit in my barn (150+ tears old). Once I got it I wished I bought it years before. One of the best investments for cars I made. I did it once your way with my C-5 and I know its a real procedure. The lift is also great for working on trans, rear, etc. I replaced the frame on my '62 a few years ago using the lift to get the body on and off by myself. I'm getting too old to lay on my back and work under the car!
nicely done.
I like the idea of the larger metal pan, I'll have to find one that I like..."Honey, where are the baking trays?"
Alvaton is a border town to Bowling Green to the southeast. South Central, Ky about an hour north of Nashville, Tn on I65. After Kentucky you live in the only other place in the world that I really, truly want to live. My wife and I try to get to Oahu at least once per year.
Nice Write up..
Anyone else notice NO MATTER what U do.. U can never keep an Oil Change from dripping on the floor at least a coupla drops... I have taken to using a cut-off oil drum.. and the oil still manages to get on the garage floor.
Thank you. I appreciate the editorial correction. Of course I knew that (now that I read it) but of course I wrote it wrong. Despite my various careers and vocations, spelling has never been a strength I'm embarrassed to say.
Grew up in the burg of Berea, a long, long time ago.
Talon........very nice write up -- very clear and to the point. I really appreciate the idea of turning the ramp around at the driver's wheel...I think that everyone who reads this is going to think (I did..)...DUH!, now why didn't I think of that?
What do you think of letting the driver's side down a bit with the jack (taking the ramp out) while the oil drains so that the drain hole is lower? Last time I did that, some more old oil came out....probably not the safest thing to do, but as long as I left the jack there, and did not lower the car all the way down on that side, it seemed OK.....
