Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior How-Tos
- C6 Corvette Total Recalls and Technical Service Bulletins
Important information to help you understand your Corvette..
recall on 09 engines,# 09043...
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,402 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
I've Googled "gm recall", "gm engine recall", "gm corvette recall" and found nothing about rings (or even engine other than a recall affecting supercharged motors such as the G8).
Must be a rumor started by those Evo guys on Bullrun
here is a copy of recall
Document ID: 2244700
#09043: Service Update for Inventory Vehicles Only - Excessive Oil Consumption - Incorrect Piston Ring - (Mar 9, 2009)
Subject: 09043 -- Service Update for Inventory Vehicles Only -- Excessive Oil Consumption - Incorrect Piston Ring -- Expires September 30, 2009
Models: 2009 Corvette
Equipped with a 6.2L V8 Engine (LS3)
THIS SERVICE UPDATE INVOLVES VEHICLES IN DEALER INVENTORY ONLY AND WILL EXPIRE SEPTEMBER 30, 2009.
Purpose
This bulletin provides a service procedure to replace the engine on certain 2009 model year Corvette vehicles equipped with a 6.2L V8 engine. Some of these vehicles may have one or more incorrect oil control rings installed in the engine. This could result in high oil consumption.
This service procedure should be completed on involved vehicles currently in dealership inventory as soon as possible but no later than September 30, 2009, at which time this bulletin will expire.
Vehicles Involved
A list of involved vehicles currently in dealer inventory is available on the "Service Update Bulletin Information" link under the "Service" tab in GM GlobalConnect used to release this bulletin.
Important: Dealers are to confirm vehicle eligibility prior to beginning repairs by using the GM Vehicle Inquiry System (GMVIS). Not all vehicles may be involved.
Parts Information
The replacement engine needed to complete this service update should only be ordered from the Product Quality Center (PQC). Contact the PQC and request an engine assembly. The full 17-character VIN will be required. All removed engines should be held until a Warranty Parts Center (WPC) Request for Return is received. DO NOT SHIP AN ENGINE TO THE WPC WITHOUT AN OFFICIAL WPC REQUEST. If you do not receive a WPC request, contact Julie Cumo at 248-371-9939.
Service Procedure
Refer to SI for engine exchange procedure.
Contact the Product Quality Center (PQC) and request an engine. The full 17-character VIN and the 09043 bulletin reference will be required when ordering.
Caution: To avoid spillage when removing from the shipping container, do not tilt the engine excessively. Do not destroy the container as it will be used to ship the removed engine to the WPC. Check fluid levels after installation.
Refer to SI and replace the engine. The removed engine should be held until a WPC request for return is received. DO NOT SHIP WITHOUT AN OFFICIAL WPC REQUEST . If you do not receive a WPC request, contact Julie Cumo at 248-371-9939.
After the engine is installed in the vehicle. The following service procedure should be used to test the engine:
4.1. Disable the ignition system.
4.2. Crank the engine several times. Listen for unusual noises or evidence that parts are binding.
4.3. Enable the ignition system.
4.4. Start the engine and listen for unusual noises.
4.5. Check the vehicle oil pressure gage or light and confirm that the engine has acceptable oil pressure.
4.6. Run the engine speed at about 1000 RPM until the engine has reached normal operating temperature.
4.7. Listen for a sticking lifter or other unusual noises.
4.8. Inspect for fuel, oil, and/or coolant leaks while the engine is running.
4.9. Perform a final inspection for the proper engine oil and coolant levels.
Return the removed engine to the WPC following the procedures outlined in Bulletin 99 00 89 019E.
Claim Information
For vehicles repaired under this service update, use:
Labor Operation
Description
Labor Time
Net Item**
V2056
Replace Engine (inc. wheel alignment)
13.5*
$400.00
Add: Adjust Rear Toe
0.2
Add: Adjust Front Toe
0.1
* The labor time shown includes 0.5 for wheel alignment, and 0.2 hr. administrative allowance.
** The amount identified in the "Net Item" column represents the part allowance for the replacement engine.
Purpose
Vehicles Involved
Parts Information
Service Procedure
Claim Information
Labor Operation
Description
Labor Time
Net Item**
V2056
13.5*
$400.00
0.2
0.1
Negative! No sign of it in my car. VIN #4370 and it's only seen 3,880 miles on it but no oil consumption issue noticed as of today! If they are doing this on existing dealer inventory that means cars with virtually 0.0 miles on them. Not good.
I just checked my calender and it's still two weeks until 1 April
I'm headed to the garage to check the dipstick!!!
I took delivery on my 2009 back in November. Is there a list of effected VIN number ranges? Hopefully mine was built after the screw up but I'm a little concerned......
In my opinion this is a major issue if GM is recommending engine replacement. If it's applicable to my car, what's the chance that I can dump it on them and make them give me a new one? (Only have about 600 miles on it now) Hate to have some dealer rip apart my brand new car to replace the engine!!!
#33
I went through this same crap with my Z06 about 9 years ago!! I remember the BS from that horror show.
I gotta tell ya, if I gotta go through that circus again I'm dumping this one and buying a effin' Viper!!
#36
Yeah right!...how much do you want to bet on what the build date of that motor was? Your car may have completed assembly on 10 March but I bet the motor came together long before that date! Don't count yourself out yet. We need to learn more about this recall and find out how widespread this issue is. It could be limited to a very small portion of the production run.
#38
Of all the potential luck seeing my previous Vette was an 01 (remember that ring recall?). But it didnt use excessive oil so am hoping the Vette gods shine down on me this time.
Good point about when the engine was built, I failed to take that into consideration.
#40
Who can look this up?
