Splash Guards
Splash Guards
I'm thinking of putting GM splash guards on my 08 vert. Has anyone installed them? If so, can you send me a picture of what they look like - I'm concerned that they stick out too far from the body of the car. Also, was the installation as easy as the instructions make it look? thanks
Received 2,485 Likes
St. Jude Donor '15
"In honor of jpee"
I did mine yesterday. Hardest part was taking off the rear wheels. Piece of cake. 1 hour max time. I checked and rechecked before I drilled the rear holes. You need to make sure you have the correct drill bit. I used an awl to make sure the holes were centered, be sure and drill slowly, its only plastic. Looks good when you finish.
Here you go. This is my install with pics... Very easy install with outstanding results..
http://forums.corvetteforum.com/c6-c...on-w-pics.html
I let the dealer do mine , i wanted it covered under the warranty
just in case....IT took him all of 15 minutes ! IMO they do look a little more classy than some of the ones i have used . Go for it !
I put the Z06'S on mine and I am happy with them. They do stick out a little further than I would like. They are on now and going to stay. I would like to put the G.M.'S ON THE FRONT. Can't find a set just for the front, you have to buy a set.
GM splash guards
Premium Supporting Vendor
I'll explain in further detail for the customer.
If you purchase a GM accessory, it is warranted for 12 months 12,000 miles.
If you purchase a GM accessory (prior to delivery) and have it installed it is now covered under the 3 year 36,000 mile warranty.
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Phone: 484-334-8833
