MILD2WILD Wireless Exhaust Controller available at Top Flight Reproductions
Take full control of your NPP/Z06/ZR1 exhaust with the #1 selling MILD2WILD wireless exhaust controller. Developed over 2 years ago, it quickly became the must have modification for any bi-modal exhaust equipped car. It’s Jay Leno’s and Scott Dixon’s (Indy 500 Winner) choice for their cars and has even been certified and used in many Corvette dealerships.
MILD2WILD installs in less than 3 minutes requires no cutting, splicing and is 100% reversible. The unit comes with two wireless micro FOBs that allow you to open the bi-mode exhaust at any time so you can enjoy that great sound anytime. You will be shocked at just how great your car will sound and with a press of the button it will set back to the OEM setting.
MILD2WILD remembers the last setting (shut off car with flaps open, starts with flaps open / shut with flaps closed, starts with flaps closed) and it also has a ZERO battery drain install.
ORDER Online at http://www.topflightrepro.com/corvet...products.shtml
The 5 MIN Wireless Install (most do it in 2min)
Use your HOMELINK (cars built after 10/06 do not use HomeLink) or THE PROVIDED MINI REMOTES. Some mounting options
Please note: Cars built after 10/06 do not have the homelink system and you will need to use the wireless FOBS provided as you can not program the visor control
Order Online at http://www.topflightrepro.com/corvet...products.shtml
I don't suppose that thing can be modified to use connecting two wires instead of the fuse box? On my XLR-V there is no single fuse that controls the baffles. However, there is one wire in the trunk area that when cut opens the baffles permanently. Some are using a simple on/off switch to connect the wire to so you can turn it on and off. However, it would be great to have a wireless application that you could use. Any chance your product can be modified for use in the XLR-V? If so I think I can sell a few for ya. Thanks!
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14
Have one already! Probably my favorite mod to date and was very easy to install. Only took about ten minutes tops. Thanks for offering a product that is second to none in the exhaust controller category
Former Vendor
St. Jude Donor '09
In Stock and Ready to Ship
