Forcecast my HP increase...
Just ordered these mods. How much HP increase do you think I will see?
1. Lingenfelter Performance Engineering (LPE) 160 Degree Thermostat (2004-2008 LS1, LS6, LS2, LS7 & LS3 Corvette)
2. VaraRam Gen2 "Snake Charmer" Ram Air System (2005-2007 Corvette)
3. VaraRam Pre-Cut Shroud (2005-2007 Corvette)
4. VaraRam LS2 Throttle Body Spacer
Also, I saw posts discussing programming the fans after putting in a 160 thermo. Is this required?
Thanks!
Thanks!
Just ordered these mods. How much HP increase do you think I will see?** 1. Lingenfelter Performance Engineering (LPE) 160 Degree Thermostat (2004-2008 LS1, LS6, LS2, LS7 & LS3 Corvette)** 2. VaraRam Gen2 "Snake Charmer" Ram Air System (2005-2007 Corvette)** 3. VaraRam Pre-Cut Shroud (2005-2007 Corvette)** 4. VaraRam LS2 Throttle Body SpacerAlso, I saw posts discussing programming the fans after putting in a 160 thermo. Is this required? Thanks!
Moderator
Received 3,594 Likes
Zilch
About 10 - 15 HP on a good day. Intake helps, T-stat helps, Pre-cut shroud helps, spacer is useless. For best dyno results have a fan running full blast in front of the car.
Thanks!
Thanks!
I never expected any significant increase, but all this was on my list of things to do, and every little bit helps. However I do find it interesting to hear people says ZERO increase, and then I read this:
On the Vararam CAI...
"10-15hp from any cold air kit,but once moving the VR will put all the lost MAP pressure back into the plenum yielding another 17hp by 60mph 19-20by 90-100mph and the way we rate our kits is through a mile Your total power through a mile is about another 22hp plus the dyno hp of 10-15hp,so, on the low side, 32 Rear wheel hp, high side 37 Rear wheel hp. That's 39- 42hp at the fly wheel through a mile. "
On the Vararam Throttle Body Spacer...
"The LS-2 applications see around 5+rear wheel hp and 10+ftlbs of Torque!"
Plus the thermo, and I intend to have the fans programmed to keep the engine much cooler...
All that and zero increase? I find that hard to believe. However I think these mods will come alive alot more after I put on headers and a custom tune...
