new roof handle
new roof handle
will gm replace the old handle if your car is out of warranty?
If not...how much do they cost?
Does the new handle solved the creeping noise?
If your car is out of warranty then the replacement will be out of your pocket. You can purchase the new handles from any GM dealer. They retail for about $145 each. You can get them from Gene at the link below for $112.00 each
The part numbers are:
19206591
Handle, Roof Lift Off Panel - Left
19206592
Handle, Roof Lift Off Panel - Right
You can get them from forum member Gene Culley at GMPartshouse.com
http://www.gmpartshouseusa.com/partl...14638&items=10
19206591
19206592
Lots of positive feedback on the new handles. Lots of testing went in to the new handles as well. However, the handles are really to address a specific issue with a rattle noise at the front latches. If you don't want to go after the handles there are a few things that you can do on your own first to see if it addresses your particular problem first.
If you haven't all ready, have a look at this thread:
http://forums.corvetteforum.com/c6-c...long-post.html
