Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Corvette General Discussion
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
General C6 Corvette Discussion not covered in Tech Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Closed Thread
Old 11-18-2008, 08:03 PM   #1
bvanhoeven
Junior Member
bvanhoeven's Avatar
Default C6 Automatic Transmission Shift Problems
Was wondering if anyone else has experienced the same problem. In the morning, when backing the car out of the garage, shifting from reverse to drive there is a delay of about 7 seconds before it shifts hard into drive. I live in Jacksonville Florida so I don't think temperature is an issue. I have tried shifting from reverse to drive before backing the car out and it works just fine, but put it in reverse and back down the driveway (a small decline at the end) and try to go to drive and it will experience the same delay and hard shift. I will take it in to the dealer but have always had luck with the forum educating me before I talk with the service department. Any help would be appreciated.
bvanhoeven is offline
Old 11-18-2008, 08:29 PM   #2
JimTN
Moderator
Support Corvetteforum!
JimTN's Avatar
No such problem with my 06 A6. Also don't have that problem when backing down my sister's extremely steep driveway, then going from reverse to drive after I get to the street.
JimTN is offline
Old 11-18-2008, 08:50 PM   #3
Daytona Bob
CF Senior Member
St. Jude Donor '09 & '12, '14
Daytona Bob's Avatar
Howdy neighbor... Did you get the rear end repair work done yet?
Daytona Bob is offline
Old 11-18-2008, 08:56 PM   #4
Oh9C6
CF Senior Member
Oh9C6's Avatar
I would recommend posting this question on http://corvettemechanic.com/forum/index.php
No bulletins are posted for this problem.
Oh9C6 is offline
Old 11-18-2008, 09:14 PM   #5
danl72
CF Senior Member
danl72's Avatar
Send a message via Yahoo to danl72
I have not noticed any issues.
danl72 is offline
Old 11-18-2008, 10:19 PM   #6
Brutus 08 Coupe
CF Senior Member
Brutus 08 Coupe's Avatar
7 seconds is a long time. Take it to the dealer if under warranty (trade it if not). No delays that long in my '08 A6...
Brutus 08 Coupe is offline
Old 11-18-2008, 10:32 PM   #7
HawaiiC6
CF Senior Member
HawaiiC6's Avatar
No problems with my 06 A6. Does this delay and hard shift happen only in the morning?
__________________
Aloha
2006 Black/Ebony C6, A6, 3LT, Z51
Comp Cam XR275HR
Stock Heads w/Comp Cams RPM Kit
Yella Terra 1.8 Roller Rockers
160 thermostat
Taylor wires
Vararam CAI,
Vararam Throttle Body Spacer
VMax Motorsports Ported and Polished Throttle Body
VMax Motorsports Ported Intake Manifold
CCA Oil Catch Can
Predator Modified Tune
Kooks 1 7/8" LT with Jet Hot Coating, Kooks Off Road 3" X-Pipes
Borla Stingers
HawaiiC6 is offline
Old 11-18-2008, 10:39 PM   #8
mercalli
CF Senior Member
mercalli's Avatar
7 seconds is way too long. Get it checked out.
mercalli is offline
Old 11-18-2008, 11:32 PM   #9
Redrocket1045
CF Senior Member
Redrocket1045's Avatar
Default A6 shifting
Quote:
Check with your GM stealership. GM TSB# PIP4395B (document ID 2180379)
* delayed/extended or delayed with a harsh feel initial Park to Drive and/ or Reverse to Drive, that are more likely to occur when the transmission temperatures is below approximately 40 degrees C.
Some customers may comment on a flare or harsh 2-3 shift.
Either way, the condition is caused by leaking 1-2-3-4 and 3-5-R clutch fluid seal rings.
Vehicles built in the January thru August time frame are more likely to have leaking fluid seal rings. Hope this helps.
Redrocket1045 is offline
Old 11-19-2008, 06:54 AM   #10
bvanhoeven
Junior Member
bvanhoeven's Avatar
Thanks for all the responses. Yes I have had the rear end work done, and it appears the shift is harder in the morning, but then in the afternoon after an extended shutdown (possibly cooler transmission temperature) it also occurs. Taking it into the dealer tomorrow will let you know what I find out.
Old 11-20-2008, 10:42 PM   #11
Redrocket1045
CF Senior Member
Default A6 shifting
I just got my Vette back from the dealership and the trans is shifting fine. No more 2-3 flare. Oh - yea; they followed the TSB that I mentioned earlier.
Old 11-22-2008, 07:08 PM   #12
2006c6keller
CF Senior Member
2006c6keller's Avatar
Default Download for transmission lag.
There is a download for this problem of "lag" in the transmission. Take it to the dealer and have them download an update for this problem, I had it done on 2006 C6 A6. Be sure to describe what it is actually doing. Good luck!
2006c6keller is offline
Old 11-23-2008, 12:31 AM   #13
Redrocket1045
CF Senior Member
Default A6 shifting
First, I had the dealer download the '08 TCM software to try to correct the A6 shifting flare. That didn't help. So - I took it back to the dealer for the August 2008 TSB. That fixed my problem.
Old 07-11-2012, 08:36 PM   #14
Avionics787
Junior Member
Default C6 transmission slammmed into gear
Here the problem:
Slammed into and out of gear within 2 seconds. Paddle shifters were
disabled. Car would not shift out of third gear (?)....45mph @ 2000 rpm.
Check engine light came "on"...stay on steady
Shutdown car and car shifts normally including the paddles. Engine light remains on...steady. GM TSB# PIP4395B (document ID 2180379) ?
Comments anybody and thanks in advance!
Avionics787
Avionics787 is offline
Old 07-11-2012, 09:11 PM   #15
JimTN
Moderator
JimTN's Avatar
Please do not retrieve old threads, especially if it's about a different problem. Start a new thread.
http://forums.corvetteforum.com/foru...s-or-more.html
JimTN is offline
Reload this Page C6 Automatic Transmission Shift Problems
Closed Thread
Tags
2006, 23, a6, auto, automatic, c5, c6, corvette, flare, gm, hard, long, servicing, shift, shifts, takes, trans, transmission
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Shifting in and out of park flby55 C6 Corvette General Discussion 14 07-14-2014 02:28 PM
Z06 trans mystery (long) GAMYZ06 C5 Tech 9 06-07-2013 12:08 AM
C5 m6: 5th & reverse gears grinding. Please help! R6cowboy C5 General 1 05-06-2013 07:12 PM
C5 m6: 5th & reverse gears grinding. Please help! R6cowboy C5 Tech 0 05-06-2013 12:36 PM
Paddle Shift, Shift Delay..08 Pugly C6 Corvette General Discussion 24 03-30-2013 03:47 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
