Removing Splash Guards
I installed Z0-6 guards on my '07 coupe a couple of years ago. My question to the brain trust is: Since these guards were installed using instructions here on the forum, using very high bond (VHB) double stick tape, can they be removed without damaging the paint? If they can be removed what would be the best way? All responces are very much appreciated.
Received 2,485 Likes
St. Jude Donor '15
"In honor of jpee"
hmm, don't know, but if it's 3M tape, I'd call them. they literally have experts that can answer your question or get back to you from the experts.
sleekvino (11-20-2023)
I just did this, never really liked the fit of the Z06 guards, removed them and installed the GCA's. Look MUCH better, but the Z06s provided better protection. Anyway, heat gun and patience did the trick, then goo-off to remove the remainder. Oddly enough, the VHB came right off, the grey factory 3m on the other hand....there were a couple of spots I had to use fishing line to kinda "saw thru" the tape.
Good luck!
Anybody wanna buy a set of modified Z06 guards - on the cheap?
Good luck!
Good luck!
Good luck!
Good luck!
Good luck!
Received 2,240 Likes
Here's a non-recommended way to remove them. I went with the new GM guards on my new 09.
St. Jude Donor '15
"In honor of jpee"
Don't know if you're talking about this one, but I forgot: I have a spray can of 3M Gen Purpose Adhesive Remover that I use for bugs and road tar. Tall, red can with white top. I guess it'd work after you pulled off the guards and some of the tape.
Good luck!
Good luck!
BJK
1 Post
Mine is not a spray.. I bought it to remove some dealer badge that was stuck on my wifes car. I applied it on a cloth and let it soak on the decal.. Slid right off.. Made by 3M for their adhesives. Good stuff as is most of 3M's products
St. Jude Donor '15
"In honor of jpee"
That sounds like the real deal. Probably the stuff 3M would recommend any way.
