Nail in Tire - Can It Be Repaired? *PHOTO*
Old 10-26-2008, 09:45 PM
rjbraud
rjbraud's Avatar
Originally Posted by CodyC6
Heck, I'd pull it and see if it is even long enough first.
Had one similar. Removed the nail and found out it had not gone through
Old 10-26-2008, 09:49 PM
rjbraud
rjbraud's Avatar
I removed a nail from my tire and discovered it had not fully penetrated. This was over a year and no problem.
Old 10-26-2008, 09:51 PM
gbgary
gbgary's Avatar
Originally Posted by FredC5
I had a similar problem with my C5 and I had it patched at the Goodyear store. They charged me $50...
Good Luck
yikes!! discount tire would have fixed it for free.
as for the tire repair...i had one just like that and their repair worked out just fine.
Old 10-26-2008, 10:33 PM
BEZ06
Support Corvetteforum!
BEZ06's Avatar
Originally Posted by Viprklr
Hey guys,
Been having a slow leak the past week and finally decided to take the wheel off. Here is what I found.
Can this be plugged, or patched from the inside...or is it new tire time?
Matt
Officially, you're screwed!!
Read this Goodyear webpage about repairing EMT's:
http://www.goodyear.com/cfmx/web/gov...e/psb_9811.cfm
You can see that if the puncture is in an acceptable repair area and is done properly, the tire WILL retain its speed rating:
"Repairing is limited to the tread area only within the outside grooves. No repairs are allowed in the tread area beyond the outside grooves or in the sidewall area of the tire."
Your nail is in the "tread are beyond the outside grooves" so is officially not repairable.
I'm not telling you to do anything unsafe, I'm just telling you what I did. I had a screw puncture where you see the plug in the picture below on a Z06 F1 Supercar tire. The tire was getting pretty smooth and I wanted to put another 500 or 1,000 miles on it to finish it off. I plugged it and have been driving locally on it for about 2,000 miles now, and I think it's about done! I did the plug in about February this year and put a few extra pounds pressure in the tire because I expected a slow leak. It didn't lose any pressure at all until about June when I needed to put a couple psi in it.
I just drove the tire for local driving (I've got several sets of whieels/tires, so I've got the luxury of swapping to another set for a long road trip or the track). These tires are runflats, for pete's sake!! You can shoot them with a 44 magnum and drive them with zero pressure for 50 miles at less than 55 mph. I had no qualms about plugging the tire for local driving - and I didn't baby it. You've got sensors, so you'll know if you start losing pressure.
Don't do anything you don't feel comfortable with, but I plugged mine with good results.
Bob
Old 10-26-2008, 11:17 PM
pewter99
pewter99's Avatar
Received 1,194 Likes on 704 Posts
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
like I said it can be done with the right technology...no regular plug or patch
Old 10-26-2008, 11:31 PM
Rocketmanwpb
Rocketmanwpb's Avatar
Matt, looks too close to the sidewall to me. If you plug it you are losing your speed rating. Don't know your driving style, so don't know if a plug will affect your safety. But a plug will definitely compromise the tire.
Old 10-26-2008, 11:33 PM
PaulB
PaulB's Avatar
Default Tires
I had something like this happen very recently. The Tire Store told me it was to close to the edge and replacement would be needed. They pulled the Nail, it was a very short nail (more the length of a tack) and the tire does not leak any air. I was very lucky...
Old 10-26-2008, 11:50 PM
GotVett?
GotVett?'s Avatar
I also think it's repairable. But, I wouldn't be going WOT on it until new set of tires.
Old 10-27-2008, 12:17 AM
C-INRED
C-INRED's Avatar
St. Jude Donor '06
I had two almost new tires replaced on my '06 for free under warranty by Goodyear bacause the puncture was too close to the edge of the tire....just about where yours is. They said it is not safe to repair a puncture within the width of a quarter from the sidewall.
Old 10-27-2008, 06:59 AM
Fastcar
Fastcar's Avatar
Old 10-27-2008, 08:22 AM
wolfdogs
wolfdogs's Avatar
Location: Stafford VA, home of our wolf den. No house break ins to date.
never plug ANY tire....
and according to NHTSA regulations, that object is too close to the crown edge to be repaired.
belt edge seperation = blow out.
Old 10-27-2008, 08:24 AM
wolfdogs
wolfdogs's Avatar
Originally Posted by pewter99
YES..they have a new liquid technology..that allows them to fix the tire even on the corner..
http://www.safetyseal.com/products.htm
my tire guy did this for me
thats for low pressure tires......not passenger and light truck.....
thats not an acceptable repair in the industry or NHTSA
Old 10-27-2008, 08:27 AM
  #33
V4Vette
V4Vette's Avatar
Whether too close to the sidewall or not (and it looks like it is) I would not and have never repaired a high performance tire. Just bite the bullet and buy a new tire.
Old 10-27-2008, 06:28 PM
  #34
Viprklr
Viprklr's Avatar
Would it not be best to buy 2 new rear tires?
Quick Reply: Nail in Tire - Can It Be Repaired? *PHOTO*
