NPP Exhaust
NPP Exhaust
I am interested in a set of GM NPP Switchable Exhaust for a C6 (not a Z06) I have a 2006 and understand the 2008 NPP exhaust is a simple swapout. If anyone has a set for sale, please let me know. Thought about going with Corsa's but I prefer to stay with factory exhaust system.
St. Jude Donor '06-'07
Mufflers waiting for Install
Factory Exhaust Removed
Drilling a ¼” hole in the rear well
Run the Vacuum Tube though the hole
Run the Vacuum tubes through existing frame locations
After dropping the rear sway bar, snake the NPP mufflers up and over
Attach the pipes to the mufflers
Connect the vacuum hoses to the NPP mufflers
Make sure your muffler pipes are straight and level
Muffler hardware done and vacuum tubing run
Connect power cable to the Seat Heater Fuse
And of course, a quick run with Ed's Polishing kit
That's all there is to it.....All that's left is to go out there and have a blast with your new found customized sound.
Here's a link to a video of the sound
Play Video
Ed, once again, THANK YOU!!!![/QUOTE]
You should be able to find NPPs for $650-850 depending on age/condition. I was able to find a set for my 09 (which, as noted, is different) from a forum member. I am pleased with the result.
I just completed the exact same mod you're looking forward to. '08 NPP exhaust on a '06, A6 along with Ed's M2W. Fairly straight forward and the best mod you'll probably do. Be patient and check the Forum For Sales and you'll find a reasonable deal...I did. Good luck!
Thanks for the heads up- I will keep searching.
I too am looking for a set of '09 NPP's. If anyone has a set, please PM me a.s.a.p.
I'm getting the car ready for storage now so I probably wouldn't have a chance to put them on this year, meaning that if anyone gets a set of aftermarkets for Christmas, please keep me in mind.
Obviously, I'd like them to be in as good a condition as possible.
Thanks!
Thanks!
Not sure why you hate NPP, unless you work for the other side . I can honestly say I can't remember anyone posting they did not like NPP and by the lack of ones for sale I would say they are keepers. I agree to each his own when it comes to exhaust sounds but you constantly try to tell people not to get the NPP
I did Magnaflow and HATED the drone. With the Z06 and NPP-IN-A-BOX and M2W, I finally got what I wanted.
I found my Z06 mufflers and over axle pipes on that big auction site for $312 DELIVERED! I know that it was a bit of a gamble but they arrived very quickly and in PRISTINE condition.
jimcattani - there are also some labor charges at your muffler shop to consider, unless you get the regular NPP set AND you can do it yourself as in Ed's tutorial. IMHO it is waaaay worth it. It is the best of both worlds, sound when you want and quiet when you need it. Some say it isn't loud enough so if you like LOUD, it won't be for you.
Thanks!
Thanks!
I just purchased and 08 set from them and they included the wireless controller with them.
