GETTING IN and GETTING OUT
Old 10-08-2008, 01:18 PM
Roc Rinaldi
Roc Rinaldi's Avatar
Default GETTING IN and GETTING OUT
OK, I'm old but I still need to learn new tricks.
What is the recommended way to easily get into and out of a C6 Corvette? I am sure that there is a process that I should follow to minimize the problems with this.
Old 10-08-2008, 02:05 PM
Smitter
Smitter's Avatar
I am an old guy too, with a bad hip. Getting in is easy once you get going gravity takes over. Getting out I put my hand on the rocker panel for an added boost. I will never give up the Corvette even if I have to crawl out. Good Luck.
AORoads
AORoads's Avatar
Received 2,481 Likes on 1,944 Posts
St. Jude Donor '15
"In honor of jpee"
hey neighbor! well, I guess there are many ways, but the easiest for me is to back into it and then swing my legs around. sometimes I put my foot in first.
getting out, I make sure to push up on the door sill using it as leverage with two legs out.
whatever you do just remember there are those little seat bolsters that supposedly wear out real fast if you keep sliding over them . I'm sure it happens to some, but hasn't happened to me in any of the Vettes I've owned.
Old 10-08-2008, 02:06 PM
BillH2121
BillH2121's Avatar
From what I've read lately, the process is very simple:
1. Make sure you are wearing the proper clothing - no blue jeans, overalls, coarse materials, dark colored clothing, or anything with coarse stitching:
2. Go through a metal detector to insure that no metal objects are in any pocket or in close proximity:
3. Assume a lotus position adjacent to the driver's door:
4. Levitate up and through the open targa top or open convertible top:
5. Gently lower yourself into the fully reclined seat.
There - no problems, eh?
Old 10-08-2008, 02:17 PM
Vette_DD
Support Corvetteforum!
Vette_DD's Avatar
Received 1,276 Likes on 935 Posts
Have the auto exit seat position set for all the way back. Have the steering wheel tilted up. Then I put one foot in, followed by the other as I lower myself into the seat, while holding onto the console and the steering wheel.
Old 10-08-2008, 02:38 PM
Ratchet Thunderbolt
Ratchet Thunderbolt's Avatar
Old 10-08-2008, 02:39 PM
ZPirate
ZPirate's Avatar
If you have memory seats the auto exit feature is great for ingress and egress. I have mine set so when I open the door the seat goes all the way back and the steering wheel retracts toward the dash. Then I tilt the steering wheel all the way up. Then once you get in push the memory button and the seat goes to your setting and then tilt the steering wheel back down.
Old 10-08-2008, 02:40 PM
Roc Rinaldi
Originally Posted by Smitter
I am an old guy too. I will never give up the Corvette even if I have to crawl out. Good Luck.
You and me both.
I wonder who the oldest person is at this forum. I'm 61. Others older?
Old 10-08-2008, 02:42 PM
Roc Rinaldi
I'm pretty much doing the same things as you are.
Yes, it was my concern for the wear and tear of the seats that caused my to post this thread in the first palce.
Old 10-08-2008, 02:44 PM
dpigguy
dpigguy's Avatar
usually just back it in and then swing the legs in. seat is in exit mode (all the way back) to help. getting out is same as above. I am only 61 so not sure I qualify as an old guy yet!
Old 10-08-2008, 02:45 PM
mrtoner
mrtoner's Avatar
Or, once you are seated and close the door, simply start the engine and the seats and steering wheel will go to your memory setting......
Old 10-08-2008, 02:46 PM
PowerLabs
PowerLabs's Avatar
Location: Greater Detroit Metro MI, when I'm not travelling.
Erm... I just get in an out just like any other car... I don't get what the difficulty is; its not like we are talking about a small car here...?
Old 10-08-2008, 02:48 PM
Roc Rinaldi
Originally Posted by dpigguy
: I am only 61 so not sure I qualify as an old guy yet!
uh.........you are an old guy.
Old 10-08-2008, 02:52 PM
jeffjob
POSSE Senior Hombre
jeffjob's Avatar
St. Jude Donor '13, '17-'18
For auto's only.
Us MN6 drivers need to push the appropriate door button.
dpigguy
dpigguy's Avatar
you could have lied and made me feel better
Old 10-08-2008, 02:58 PM
ALD_Z06
ALD_Z06's Avatar
First things first.
Open the door.
Old 10-08-2008, 02:59 PM
Roc Rinaldi
When will you be 62?
To GETTING IN and GETTING OUT
Old 10-08-2008, 03:01 PM
dpigguy
dpigguy's Avatar
June next year. I refer to myself as experienced which seems to ease the pain of getting older by the day. Neat thing is when I am in the car or on my bikes I feel 29 ........... again!
Old 10-08-2008, 03:09 PM
Roc Rinaldi
See, you are my junior partner. I will turn 62 this November.
Old 10-08-2008, 03:12 PM
dpigguy
dpigguy's Avatar
Quick Reply: GETTING IN and GETTING OUT
