Unexplained Beeping/honking
1 Post
St. Jude Donor '05 '09
I'm sorry if this topic has been discussed already but a search turned up nothing.
I've had my 2007 C6 Z06 about a month and a half and about 4 or 5 times now when I have shut off my car and gotten out of the vehicle it has beeped/honked at me 3 times in a row. I can't figure out what the "warning/alarm" means. In all cases I have had my fob in my pocket and in every case when I have returned to the car (after an hour or two) the car exhibits the "dinging" alarm when I enter the car until I close the door.
I was going to ask a friend of mine (who has an '08 C6) if he knew what it was about and before the words even got out of my mouth at a recent get-together, his did exactly the same thing and he disavowed any knowledge of an explanation.
Does anyone know what this is all about??
Tom
Tom
Received 2,485 Likes
St. Jude Donor '15
"In honor of jpee"
Yeah, it has something to do with the fob recognition, etc. etc. After awhile from time of engine shut down, fob tells car to beep to tell you you're nearby and may have left the fob in the car or some such thing. As to the dinging on entry, not sure. Did you like that explanation? Think I could be more vague?
One of these days, when it gets really important to me I'll go read up on it in the manual. If you get there first, pm or email what I should do and I'll make up a little sticky and put it in my garage. I mean, after all, what are friends for?
St. Jude Donor '08-'09-'10-'11-'12
If you're getting out of the car in the garage or some other place where its kind of tight and you only open the door enough to get out, the car sometimes registers the fob as still in the car and gives a 3-beep warning. Mine does it sometimes in the garage.
Cruise-In VIII Veteran
I get the same 3 beep warning if I'm standing too close to the side of the car when I close the door. If you have the room, stand back a bit and you probably won't get that warning.
I tried reprogramming it on the DIC, but it made no difference. I just reset the seat settings for the fob and will see if that makes any difference. If I can't figure it out, I'll let the dealer play with it and see if he can correct it. I'm sure it's a programming glitch in the fob itself.
This 3 beeping has happened to me. Like foremaw said, it is when I'm in the garage and open the door only enough (barely) to get out....
I get the dinging alarm when fob #2 is used to enter the car. It doesn't do it all the time, but enough to be annoying. It also stops when the door is closed and everything works normally. It never does this with fob #1.
Have your dealer try this....(This was printed before '09 Model Year)
PIC4642A Occasional No Fob Detected Message on DIC or Key In Reminder When Key Fob Outside of Vehicle - keywords chime chirp horn no program RCDLR RKE transmitter - Jan 14 2008 Models 2005-2008 Chevrolet Corvette Cadillac XLR and V-Series
2005-2007 Software Version 25927325
2008 25927326
This was posted on the forum a while back. I printed the full copy and have full instructions for your dealer if you need it.
I had the same problem and actually I think it's worse. I'm sure it works for others.
It's normal, it will honk three short blasts when you get in and out of the car without closing the door and then close the door with you (and the fob) inside the cabin. It's trying to remind you about the fob possibly being left in the car unattended, and therefore tantamount to leaving the keys in the ignition.
Tom
Tom
BTW, I have gone to the FOB in left pocket also, which seems to have pretty much eliminated the car's confusion.
Exactly what happened to me about an hour ago.
Three Beeps
Got to the DIC and turn off the fob reminder. This will stop the three beeps, but your car will still chime when you enter if it thinks your fob was left inside, Since the car battery has a tendency to run down, I turned my reminder off to save battery ALSO, since my bedroom is above the garage, my wife no longer hears three horn beeps telling her I am sneaking off at 6 on Sunday morning to go for a drive again!
