Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: General How-Tos
- Corvette: How to Fix Popping Noise
Step by step instructions for do-it-yourselfers.
C6 Coupe roof panel noise primer - Long post
#222
I did the TSB fix at the dealer. Lots of the sticky lubricant on the weather strip...made a big mess. Noise was gone for a few days and now is back just as bad . I did not like the goo the slathered all over the weather stripping....
#223
Update 11/20/09:
Well after a week the noise came back but only on the driver side toward the front. So I'll look into other fixes on this thread. No noise from the passenger side.
#224
2010 GS Roof Panel Squeak
I had a problem with my roof panel and found that the fixed roller on the driver's side latch had an excess of epoxy glue which was preventing the roller from seating properly. I used a razor blade to remove the extra glue so that it looked like the one on the passenger side, no more squeaking.
#225
Sham-WoW Fix for roof noise!
I pretty much tried all the fixes....including the new dealer latch. The popping always came back. I got tired of the mess with the silicone. I read in the string that someone suggested using a piece of microfiber. You put it in between the rollers and the latch.
Soooo, I tried that. Worked for a day. Then the light came on. (The one in my head). Sham-wow!
The Sham-wow's are worthless in my opinion to wash the car.....so I have a few lying about. I cut a couple of small pieces off and fit them in between the roller and latch. It is just thick enough and strong enough to not fall apart.
noise free for the frist time in over a year. Thanks Vince the Sham-Wow guy. (Did you cathch that camera guy?)!
Stay tuned....
Desert Dog
Stay tuned....
Desert Dog
#226
Stay tuned....
Desert Dog
Stay tuned....
Desert Dog
thanks,
jim
#227
Stay tuned....
Desert Dog
Stay tuned....
Desert Dog
#228
My '09 with 4,000 miles started sounding like a Geiger Counter, when it started warming up some about a month ago. Two weeks ago, I read the TSB and got the Super Lube from my friendly, Chevy dealer and followed TSB instructions.
To date, it's as quiet as a church mouse. Never heard of 'weatherstrip itch', prior to reading the TSB. Good luck to y'all on your C6's.
oz
oz
#229
quiet as a mouse
After reading this post (thanks talon90!!! ) I went to the dealer yesterday to have them check out my creaking problem. They installed the new handles and now...
...it's so quiet.
I just bought my 08 C6 last Thursday and this has been my only complaint.
I love this car.
...it's so quiet.
I love this car.
#230
For you guys who are still using the silicone lube to combat the roof noise, after the first application are you cleaning the weather stripping or just applying another layer of lube over the first layer?
I haven't been cleaning mine and I am curious if this is creating more problems. The weather stripping is tacky, white, and dirty. I just tried cleaning it with a damp rag, but the water wasn't great for cutting the lube.
Has anyone used a product to clean the weather stripping between lube applications?
My popping roof noise is driving me completely nuts. I realize there is thermal expansion, but this thing sounds TERRIBLE. I have tried everything but adjusting the front brackets on the car.
#231
'06 Fix?
Took my '06 in last week and they completed recall roof replacement and four days later the rattles started. They claim the handle replacement is not a recall and I am on my own for $400 to replace handles.
Anyone else had this great dealer service experience ?
#232
squeaky roof
Hi,
I just want to thank you for this post. After reading it, i went down to my car and greased all the suggested spots. I then took the car out for a drive and no annoying noise. YEEEEEAAAAA.
#233
Location: BOOMER SOONER Big 12 Champions 2000, 2002, 2004, 2006 - 2008, 2010, 2012, 2015 - 2020.....
Well, here we go again. Last month i experienced the popping roof, so i added the Super Lube to the latch pins and other contact points as pictured on page 1 of this thread. I took the roof off on a few nice days so im guessing that might of dried out the lube perhaps? Reason i say that is because ive been driving the vette again this week and as the temps have warmed up the popping noise has returned. So i lubed it up again last night and drove the car into work today, and the noise is STILL THERE, though not as prominent as before. Nice design flaw, GM! My C5 never had any problems with the roof and i took it on and off hundreds of times.
I guess im a bit disappointed, because the last two times i applied the Lube the problem went away. Not sure why it came back so soon or why it didnt go away this time. Maybe i need to take the car into the dealer? Or maybe i need a Z06 or a vert. I love taking my roof off on nice days, but im serious here, im beginning to wonder if GM should have just made the C6 coupe an FRC with all of the problems they have had! The C5 never did any of this popping. The C6 Z06 doesnt have the popping roof or delamination problems either? Wonder what it will take to get this annoyance fixed?
#234
Cruising
Fixed my creaks
I have a 2009 C6 which I purchased in August 09. The transparent roof panel was making a loud creaking/popping sound coming from the front driver and passenger side from the day that I got it.
The new wedge type latches were already installed on the top when I got the car. I took it to the dealer for another warranty issue in Oct 09and asked them to take a look at my creaking roof. They looked into the issue and according to the work order, adjustments were made to the latches and lube was applied and the problem was supposedly gone.
When I got the car back, it was as loud as it had been prior to dropping it off - no noticeable change in the creaking sound. After months of putting up with this noise, I finally decided to read this thread and attempt my own fix.
I inspected the roof panel and the front latches looked fine. My front pins already had o-rings installed on them. The "pinched" steel plates on which the wedge slider sits was also nice and tight. Only thing I did was apply a silicone o-ring lube to the weather stripping seal on the car all along the front and rear stripping and some on the front pins and orings. Put the top back on and drove for 50kms and so far the creaking sound is gone.
Just wanted to share my problem/solution. Many thanks to the people who have contributed to this thread; I appreciate the efforts of all.
#235
Yeah, I applied the SuperLube to the weatherstrip, as well. I think that was what cured the problem. The Technical Service Bulletin called the affliction "weatherstrip itch".
Mine is still creak-free.
oz
oz
#238
i have 82,000 miles on my '06 che'vette! It's had the roof replaced with the new warranty roof, It's been adjusted and had the velcro pieces added at another shop. ( they scratched my roof when they had it off)
Mine sounds like a Jiffy-POP popcorn pan on the stove. Cold weather, hot weather it just makes noise.
I'm ready to BOLT THE FRICKIN THING DOWN!
Does anyone sell a kit to convert the top to a ZO6 style? I'm not a convertable top guy and I'm really sick of the noise and embaresed to have a pasenger!
#240
