Problem with C6 2008 NEW car....
Old 10-04-2008, 11:16 AM
Tiago Brito Ferreira
Tiago Brito Ferreira's Avatar
Default Problem with C6 2008 NEW car....
I’m from Brazil…. and here we dont have GM dealer that knows about Corvette... I bought a new Corvette C-6 / 2008 (from Tom of Marrone Pines Blv - Miami). I shipped the car over sea until Brazil, they but the car in container and turn OFF the battery (negative).
When I’ve got I fix the battery (negative) after that I turn ON the car.
The car was all right but after first 200 miles some problems appear.
I was driven and some lights start to appear in panel, first Tire pressure, anti-lock brakes system, park brake light and air bag lights, torn ON too. At same time the warning messages appear on DIC :
- SERVICE ACTIVE HANDLING SYSTEM
- SERVICE ANTI-LOCK BRAKES
- SERVICE TIRE MONITOR
- SERVICE VEHICLE SOON
- SERVICE FUEL SYSTEM
I tried to stopped the car turn (engine off), waited 10 min. and started engine again. In a fill seconds the panel all lights came ON again.
It’s very stranger, at morning all the car/panel works fine in the first 8 min, after that…. the Traction Control lights on panel turn ON ….and after more 3 min. other lights (SECURITY SYSTEM , ABS, AIR BAG, PARK BRAKE), turn on too.
I’ve check with SCAN tech-2, it lives some DTCs messages:
U2108 Lost Communication With Electronic Brake Control Module (EBCM) BCM,
ESC, TCM DTC U0100-U0299 or U2105-U2199
U1000 Class 2 Data Link BCM, DDM, DDS, DPM, DRR, FTC, HUD, IPC, PDM, Radio,
RCDLR, SCLCM, SDM, VCIMDTC U1000 and U1255
U1096 Lost Communication with Instrument Panel Cluster (IPC) BCM, DDM, HUD,
HVAC, PDM, Radio, SDM DTC U1001-U1254
C0561 System Disabled Information Stored EBCM DTC C0561
U1000
U1000
U1000
U1000
U1164 Lost Communications with Driver Door Switch (DDS) DDM, DPM, DRR, IPC,
PDM, Radio, RCDLR DTC U1001-U1254
U1301 Class 2 Data Link High DDM, DDS, DRR, HVAC, IPC, PDM, Radio, SDM, VCIM
DTC U1300, U1301, or U1305
U1164 Lost Communications with Driver Door Switch (DDS) DDM, DPM, DRR, IPC, PDM, Radio,
U1064 Lost Communications with Body Control Module (BCM) DDM, DDS, DPM, DRR FTC,
HVAC, HUD, IPC, PDM, Radio, RCDLR, SDM, VCIM DTC U1001-U1254
U1024 Lost Communications with Transmission Control Module (TCM) DDS, DDM, DPM, FTC,
IPC, HUD, PDM, Radio, RCDLR DTC U1001-U1254
U1017 Lost Communications with Engine Control Module (ECM) DDM, DDS, DRR, FTC, HVAC,
U1128 Lost Communications with Radio DRR, IPC, HUD DTC U1001-U1254
U1017
U1064
U1301
U1300 Class 2 Data Link Low DDM, DDS, DRR, HVAC, IPC, PDM, Radio, SDM, VCIM DTC U1300,
U1301, or U1305
U1000
U1301
U1301
B1440 Power Mode Master Input Circuits Mismatch RCDLR DTC B1440
P0690 Engine Controls Ignition Relay Feedback Circuit High Voltage ECM DTC
P0685, P0689, or P0690
Curiosities :
PS1: - When a turned on the Traction control system( first 50 miles), the (TSC Traction Control system) light still ON in the panel. Is it common ???
The TSC was working, but I try to turn it off but it still working, I tried to slippery but the TSC doesn’t turn OFF, and I’ve checked the ABS Brakes and it works too.
PS2: - Some times the watches in panel goes all DOWN ( Fuel, Battery, Oil pressure, RPM, Engine temperature and some times the lights too. It doesn’t following a constancy. It works different every time, any time. (It works all right only at morning (first 10 minutes)
PS3: - When the problems appear in panel, I’ve observed that the turn lights work a little bit slowly in the panel, but the lamps out-side works all right.
Things that I already did:
1- I already double checked the Battery… turn it off waited 30 min and turned on. But the problem still appear.
2- I’ve tried to change the battery, but still the same problem.
3- I checked the grounding near the engine and in the back off the car.
Any idea what is could be ??? What can I try ???
Please help me ….I’ll thank you for the rest of my life…
Old 10-04-2008, 11:55 AM
kellf190
kellf190's Avatar
At a quick glance it sure sounds like a wiring or connection issue. Seems the error codes point to the BCM. I would check all the connections to the BCM which is located in the right foot well behind the carpet. Disconnect the negitive terminal on the battery first. Is there any change or sign the car had water around it?
Old 10-04-2008, 12:05 PM
phileaglesfan
phileaglesfan's Avatar
With all the loss communication faults I think a loose connector is your problem somewhere in the car. I would check the fuses since the problem seems constant. A fuse could have been fried when the battery was connected.
The Traction control comment sounds somewhat strange. Push the button and the light will come on normally. The traction control is on when you start the car until you push that button. Regardless, I would try to figure out what the problem causing the codes are first.
It could be relatively simple to fix. Was the container water tight?
Old 10-04-2008, 12:09 PM
Stangar
Stangar's Avatar
Disconnect the battery for a few minutes and then reconnect like he said.
If that fails, my second step would be to get a fresh, new, quality battery.
Good luck and let us know what happens.
Old 10-04-2008, 12:17 PM
Have no water aroud it ... in never got rain or wash .... no water
Old 10-04-2008, 12:28 PM
We checked all the fuses is fine.... i've already changed the battery.... but the problens still appear.....
Coriosities: The car works all rignt at morning during 10 min.... and at first 200miles the car was perfect
Old 10-04-2008, 12:29 PM
jabez
jabez's Avatar
This would be my first step.
Old 10-04-2008, 12:38 PM
danl72
danl72's Avatar
Old 10-20-2008, 11:01 PM
KarlK
KarlK's Avatar
Location: Beats UD regularly playing 3D chess, and at life
BCM.
Do you have on star? GM has a TSB on the module.
Plug on the back of the tranny loose?, not clipped?
Old 10-20-2008, 11:12 PM
Rocketmanwpb
Rocketmanwpb's Avatar
If disconnecting the battery does not solve the problem, I would try your local GM dealer. The dealer should be able to handle the problem because other GM vehicles use the same type of computer controlled system to operate the car. Although they may not know Corvettes in particular, they should be experienced enough through the repair of other GM products to handle this problem.
Best of luck.
Old 10-21-2008, 12:14 AM
I'm trying with GM but they do not have corvette dealers in Brazil....
Old 10-21-2008, 12:19 AM
Originally Posted by KarlK
BCM.
Yes my car have On Star ( in the mirror, right?)... you think that the problem could be on this ? It's connected to TSC?
Old 10-21-2008, 12:50 AM
BDharley07
BDharley07's Avatar
Onstar can do a vehicle diagnostics. I say check fuses and then disconnect the battery to clear bad codes.
Old 10-21-2008, 07:05 AM
I already disconeted the baterry .... do you know where the onstar are located for check the conections or if it have a problem ?
The onstar have any conection with TSC? ou DIC / BCM?
Old 10-21-2008, 07:20 AM
KarlK
KarlK's Avatar
On star module is under the pasenger seat? There is a recent GM TSB on 2008's on faulty OnStar modules.
Do you have an aftemarket stereo?
Old 11-08-2008, 09:19 PM
Any body knows were can i find these recent GM 2008's TSB in the internet ? ( On Star modules and more info....)
Old 11-08-2008, 09:28 PM
What means "aftemarket stereo"? Sorry my english is very weak.
To Problem with C6 2008 NEW car....
Old 11-08-2008, 09:35 PM
AORoads
AORoads's Avatar
Received 2,478 Likes on 1,941 Posts
St. Jude Donor '15
"In honor of jpee"
"Aftermarket stereo" means, do you have a new radio/stereo? If you have only the original stereo that came with the car, that's fine.
By the way, Karl K, I thought the OnStar module was the black box located to the right of the inside mirror, high up on the windshield?
Your english is fine, Tiago.
Old 11-08-2008, 09:38 PM
PeterC4S
Cruising
PeterC4S's Avatar
Is the car stereo the original car stereo from the factory? Did you add any options at the dealer or by yourself? I would take it to a GM dealer. It doesn't matter that they don't have specific Corvette dealers near you, a GM dealer should be able to help.
Old 11-08-2008, 09:39 PM
AORoads
AORoads's Avatar
St. Jude Donor '15
"In honor of jpee"
he said in his original post, there is NO GM dealer in Brazil that knows about Corvettes.
Quick Reply: Problem with C6 2008 NEW car....
