Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Corvette General Discussion
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
General C6 Corvette Discussion not covered in Tech Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Closed Thread
Old 09-21-2008, 10:37 PM   #1
KevinZ51C6
CF Senior Member
KevinZ51C6's Avatar
Default Interior light won't turn off
The two overhead dome lights in the bottom of the rear view mirror won't turn off. I can't find anything in the manual about it. The car is off right now with the lights still on. I'm concerned it's gonna drain the battery. Any ideas?
Kevin
KevinZ51C6 is offline
Old 09-21-2008, 10:42 PM   #2
STEVE MC
CF Senior Member
STEVE MC's Avatar
You probably hit the dimming switch to the right of the steering wheel.
It also turns on the two rear view mirror lights
I sometimes do the same thing when cleaning the interior.
STEVE MC is offline
Old 09-21-2008, 10:45 PM   #3
STEVE MC
CF Senior Member
STEVE MC's Avatar
Sorry, meant to say left side of the steering wheel.
STEVE MC is offline
Old 09-21-2008, 10:51 PM   #4
JimTN
Moderator
Support Corvetteforum!
JimTN's Avatar
As indicated above, you've pressed the dash dimmer switch.
2005 owner's manual, page 3-18.
Quote:
Courtesy Lamps
When any door or the hatch/trunk lid is opened, the
interior lamps will go on unless it is bright outside.
You can also turn the courtesy lamps on and off
by pressing the instrument panel brightness ****.
JimTN is offline
Old 09-21-2008, 10:54 PM   #5
mpuzach
CF Senior Member
mpuzach's Avatar
Seems like this question gets asked as often as, "What's that little red light on my passenger side visor bracket?"
mpuzach is online now
Old 09-21-2008, 11:00 PM   #6
KevinZ51C6
CF Senior Member
KevinZ51C6's Avatar
I tried messing with that **** but it made no difference. They're staying on no matter what. Is there a specific fuse I can pull?
Old 09-21-2008, 11:24 PM   #7
Devil Dog 00023
CF Senior Member
Devil Dog 00023's Avatar
Get inside... close both door (completely) and the rear hatch... press the **** one time and check lights by holding you hand under the mirror... if you pressed the **** with a door open the light will of course stay on...
Devil Dog 00023 is offline
Old 09-21-2008, 11:26 PM   #8
Force-1
CF Senior Member
St. Jude Donor '08-'09-'10-'11-'12
Force-1's Avatar
Location: Albuquerque, NM "I'm the best there is. Plain and simple. I wake up in the morning and I piss excellence."
Battery Run-Down Protection
This vehicle has a feature to help prevent the battery from being drained in case any of the following lamps are left on; the underhood lamp, if your vehicle has this feature, vanity mirror lamps, cargo lamps, reading lamps, console or glove box lamps. If any of these lamps are left on, they will automatically time-out after about 10 minutes. To reset it, all of the above lamps must be turned off or the ignition key on.
Force-1 is offline
Old 09-21-2008, 11:27 PM   #9
cclive
CF Senior Member
cclive's Avatar
Quote:
Check this thread and do what I put in post #4....should take care of it...and explain why also...
http://forums.corvetteforum.com/show....php?t=2007835
cclive is online now
Old 09-21-2008, 11:31 PM   #10
KevinZ51C6
CF Senior Member
KevinZ51C6's Avatar
Thanks alot guys, they're finally off, I was about to pull the damn lights out with needlenose pliers
Thanks again
Kevin
Old 09-22-2008, 09:05 AM   #11
Wezel
CF Senior Member
Wezel's Avatar
Just for info: The on/off buttons on the mirror work backwards (to me); pushed in is off, popped out is on.
Wezel is offline
Old 09-22-2008, 09:18 AM   #12
maxp
CF Senior Member
maxp's Avatar
Thanks again
Kevin
every new owner ask this question welcome to the club
maxp is offline
Old 09-22-2008, 10:05 AM   #13
StanNH
CF Senior Member
StanNH's Avatar
This has got to be the stupidest design for a switch that I've ever seen. Other than testing the interior lights after they should be off, there's no way of knowing if the switch is engaged or not.
With all the little improvements and refinements that have been made to the car since 2005, I would have thought this one annoying little button would have been history by now. For 2009, it's exactly the same.
I think if someone offered an aftermarket replacement for the dimmer/interior light switch they'd sell out overnight.
__________________
Stan
In the White Mountains of New Hampshire
2009 C6 3LT vert, 6 speed manual, F55, polished wheels, NPP, Cyber Gray with red interior. Z51 sway bars, Pipe Dreams splash guards, and Top Flight front license plate bracket. SOLD
Gone but not forgotten: 2005 silver coupe with red interior, 1SB, MN6, Z51, Corsa Sports.
StanNH is offline
Old 09-22-2008, 10:39 AM   #14
GotVett?
CF Senior Member
GotVett?'s Avatar
When I bought mine and drove 4 1/2 hrs. back from Atlanta, I didn't notice mine were on untill the next day. Also couldn't figure it out until I too got forum help. Thankfully, it must take more than that to run down the battery.
GotVett? is offline
Old 09-22-2008, 01:43 PM   #15
loubob57
CF Senior Member
loubob57's Avatar
Quote:
Yup, I had to ask the same question here the first week I had my car.
loubob57 is offline
Old 09-22-2008, 01:46 PM   #16
maxp
CF Senior Member
maxp's Avatar
year after year the same complaint, would it really cost that much to change the design or location?
maxp is offline
Old 09-22-2008, 04:32 PM   #17
LOUSVETTE
NCM Member
LOUSVETTE's Avatar
At least the '09's has a much more solid click when you push it in so you know you're doing SOMETHING!
LOUSVETTE is offline
Old 09-22-2008, 04:46 PM   #18
Paul Scarpelli
CF Senior Member
Paul Scarpelli's Avatar
Send a message via AIM to Paul Scarpelli
You are obviously a Master Mechanic. Couldn't find a hammer??
Paul Scarpelli is offline
Old 09-22-2008, 07:38 PM   #19
Force-1
CF Senior Member
Force-1's Avatar
Quote:
See post #8.
Force-1 is offline
Old 09-22-2008, 07:46 PM   #20
Brian Fisher
CF Member
Default Dimmer Switch
This happened on my 05. Push the dimmer switch to turn them off, push it again to turn them on. There is no LED feedback on the dimmer switch, so if the lights stay on, it got pushed. Of course, you need to be in the car with the doors closed.
Brian Fisher is offline
Reload this Page Interior light won't turn off
Closed Thread
Tags
c5, corvette, courtesy, dimmer, interior, light, lights, mirrir, mirror, rear, rearview, turn, view, wong, wont
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Secret interior light switch mforman42 C6 Corvette General Discussion 9 03-04-2005 09:59 AM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
