HELP with water spots. Pics.
HELP with water spots. Pics. --Problem solved
After some very helpful tips from forum members my finish problem is solved. I used the bugmanweb.com solution to my problem. First was a thorough wash with Dawn with an amazing result. 98% of all the water spots disappeared. The water etching must have been in the 4 coats of REJEX that have been applied since the car was new. Thank God for this product. It is amazing. After the Dawn wash I used the 3M rubbing compound [3M#39009] then the finishing glaze [3M#39002]. I'll let this set over night then go over everything with REJEX including the glass and top. Before and after pics.
While at a local golf course today my car was sprayed by the sprinkler system, went haywire and got about 10 cars. The water must be well water considering what looks like calcium deposits all over my car. It was baked on for a couple of hours in 90 degree heat. I put a fresh coat of Rejex on last week. I'll wash it in the morning. Then go from there. Any suggestions.
I just finished using viniger and a wash. Spots 90% gone but I can still see the faint remnants in the right light. I've tried NXT,Rejex,Kit swirl remover, and Eagle One Nano wax. Spots still there but very faint. ANY OTHER SUGESTIONS.
After
After
I wash it as soon as possible.
Received 1,921 Likes
oh crap.
Get this fixed, professionally, asap. Until then keep it out of the sun, and you might try vinegar.
The problem is, if you do not fix it before it etches the paint top coat, it cannot be easily fixed.
I had this happen to my '04 Mustang GT and it was a nightmare.
Sorry about your situation.
Vinegar! And don't scrub with it, try to keep the paint wet with it for a little while, keep mooshing it around with a sponge or rag. The vinegar will take a bit of time to dissolve that...give it time to do its work....wow nasty! Good luck!
Vinegar! And don't scrub with it, try to keep the paint wet with it for a little while, keep mooshing it around with a sponge or rag. The vinegar will take a bit of time to dissolve that...give it time to do its work....wow nasty! Good luck!Today 09:39 PM
Vinegar/water solution would be your best (first) bet. If that doesn't work, start with the mildest rubbing compound, and then work up, toward the more abrasive ones. I've had very good luck with the Zaino scratch/swirl remover (I forget the number, but it is a lime green color). If all that fails, you will have to get a professional involved. A friend had this exact thing happen to his mint red Firehawk convertible. In the end, he had to have the entire car recleared. Insurance company paid for it. Good luck.
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'17,'18-'19-'20-'21-'22
Hope you put the golf course on notice. You should send them your pictures as well. Better chance of them paying if you have an invoice from a professional detailer, rather than a list of do-it-yourself steps you took. Good luck getting it repaired to your satisfaction. Without REJEX it would have been worse.
Find a clear coat safe scratch/swirl remover such as the one turtle wax makes and do the effected areas by hand with a micro fiber wax applicator it will look just fine. Then re apply your wax, so whats up with the Rejex didn't work to well did it?
Check out Bugman's site, he show's how to use rubbing compound to cleanup your clearcoat, also product for your glass.
I've had REALLY good luck with Zaino PC Fusion.
http://www.bugmanweb.com/c6/c6index.html
This is hard to believe but is 100% true. Same thing happened to my '06 LeMans Blue Coupe a few months ago at work. I did not have time to do anything to it and two days later it came a good rain while at work. Every water spot was gone, not even a trace of them anymore. Call it acid rain or whatever but it definitely removed the hard water spots.
Spots
Ask your GM dealer paint shop what to do! Me I would wet sand w/1500 and about 5 swipes feel the water glaze, don't go too far down where you hurt the clear coat, when you think the surface is fairly even with the paint whip out the POWER BALL and do the same thing...5 strokes...check...5 more ....and so on....let us see the finish when done.....
