Installed SIR-GM1 yesterday!
I know I will get flamed because XM and SIRIUS merged but I ordered the SIR last week and received it Tuesday. I installed it yesterday in about 10-15 minutes. I took time to shrink wrap the antenna connection so it would not come off thats why it took so long. Activated it and holy s**t what a better sounding unit! I dont know if the electronics are better or what but I do have to say the sound is much better. I noticed the signal dropped a couple of times for a second or two but XM did that also. I know I could have kept XM and eventually gotten SIRIUS on the XM unit but I dont think the sound quality would have been as good. Besides, until the whole package merger thing is ironed out I will get a good sound with killer SIRIUS channels for a minimal cost of 55.00 dollars for the unit. For those wanting better sound in the meantime, go with the SIR-GM1. Just my 2 cents worth!
You did the right thing, the content will be the same for a while with each service with the ability to add premium programming (some channels) either way, there won't be one set of channels for a couple years. My 3-month XM trial will be over soon, whom did you purchase the unit from?
St. Jude Donor '08-'09-'10
I, too, just switched out to the SIR-GM1 unit, having been a 2+ year Sirius subscriber... and yes, the sound quality is much better. There is nothing on XM that I'd want, when the time/option comes.. I'll be set for a long time, since Sirius is all I want.
I got a SIR-GM1 for Christmas, I kept using the XM antenna, rather than install the Sirius version. It seems to work just as well. I'd read it does make a little difference but none so significant that I bothered to change the antenna.
i have sirius on other cars. When i traded by 05 c6 to my 08 with xm, i was blown away by how miserable the sound quality is. i guess they split the bandwidth a lot more than sirius. i like sirius' programming better so was happy about this whole merger business.. but now i'm wondering if switching the unit out is worth it just for sound quality or maybe when sirius starts pushing xm channels, if they will have to drop the bitrate of their channels too and basically have the same sound as XM.
The CEO of the new company advised that it will take about 15 years to combine the two channels because the signal for each company is broadcast by a different satellite, said need to launch new satellites that transmit on both frequencies. Advised they will see which channels to provide on both services, should start seeing overlap by September.
All good info. I can't stand XM's low quality, either. I think they compress it more than Sirius, and even with the merger I see that the transmission mediums won't change for a while.
if xm is using 100% of their satellite bandwidth and sound crappy, then they add more channels, the quality will either be worse or drop original channels.
so yes, in other words, higher compression or lower bit-rate alotted per channel.
So in conclusion: i feel though this situation is a positive because of added channels, i do feel until new satellites are launched (15 yrs as previously stated), the quality of audio is going to drop.
With your current XM tuner, you will NOT be able to get Sirius stations until they come out with a tuner that can receive both signals.
And even then, I believe you'll be limited as to how many Sirius channels you can get with an XM subscription... and it'll cost extra.
Has anyone tried to switch their already paid subscription from XM to Sirius?
I have Sirius in my truck, and it is far better quality than XM.
I would like to install the SIR-GM1 in the Vette, but hate to waste a 1 year paid XM subscription.
Old tuners from either former company will receive select channels from the other carrier at no additional charge. It's just a matter of sending the stream to their satellites. Thats why there will be a drop in audio quality.
Also where did you install the Sirius antenna ?
I've had the SIR GM1 unit since it came out on my Coupe and I am use the existing xm antenna but I get a LOT of drop outs. I think I am going to switch it to the sirius antenna that came with the unti but I didn't want to have the sirius antenna showing.
Originally the first time I hooked it up I used the Sirius antenna and velcro'ed it to the inside of the rear hatch. It was ugly and the wire was exposed in the hatch area.
Any advice would be really appreciated.
Thanks !!
