9k Milles Too Long for Oil Change.
If I had followed the oil life monitor I would still not have changed it. It was at 30% when I changed it.
did first change at 1000 miles. now at 6000+ with 51% left on the DIC monitor. 5 months to go before I hit the once a year limit so I expect to change oil when DIC hits 10-15% sometime before the end of the year.
Can you post the actual numbers from the oil analysis report? Blackstone tends to make some questionable comments on their reports from time to time, they'll say the wear metals were high when in fact they were perfectly normal.
I recently did my 3rd oil change and it appears that 9k miles is too much.
I changed at 2500 then 8700 and most recently at 17,800.
Here is the quote from Blackstone:
"This oil was in use for 3 months and 9,133 miles. The wear metals improved compared to the
first sample, but are still higher than normal for the GM 6.2L V-8. The long oil change interval is the main
culprit; the long oil change interval is allowing metals to build up in the oil and make it abrasive.
We suggest you cut your oil change intervals by half
to help your LS-3 wear better."
My next change will be at 4500-5000 miles.
So, I will ask a few question and just give you my two sense.
First, who the heck is "Blackstone"? Not that it's revelent here.
Here's my take FWIW? Most true group IV base stock synthetics (Mobile 1 is that!) will easily go 12k in newer cars and trucks with quality filters! I would ask you what filter are you using? You can screw up a good oil life with a lousy filter.
I have run trucks (towing) and cars 15K and sent the oil off to be tested and everything came back still good. Now.. do I want to push it more.. no way! I would say 10 to 12 K is good unless you have a very harsh condition (dirty air, towing, extremely hot, very short trips etc).
Here is a great reference for all you want to know about oil and filters.
www.themotoroilsite.com
http://www.knizefamily.net/minimopar...ers/index.html
St. Jude Donor '08
I called the Rep at Mobil 1 a few years ago and he told me that the oil is still fine even after 12000 miles, but he stated that changing the oil filter every 3000 is advised. That makes sense to me, but if I'm going to get dirty with the filter, I'll change the oil, too. I do mine every 5k.
This is kind of scary. I did my initial change at 2000 mi. Since then, I've put another 8000 mi and if I use the reference on the DIC I will have over 12,000 mi on the oil when it needs to be changed. Now, all of my mileage is highway driven and not tracked. I just wonder why there are such large differences on the oil life from vehicle to vehicle. How does the computer determine oil life?
the less often you change is less money for the oil test company,think about that. i change once a year BUT i change oil filters every 4000 miles
Engine Oil Life System
When to Change Engine Oil
Your vehicle has a computer that lets you know when to
change the engine oil and filter. This is based on
engine revolutions and engine temperature, and not on
mileage. Based on driving conditions, the mileage at
which an oil change will be indicated can vary
considerably. For the oil life system to work properly,
you must reset the system every time the oil is changed.
When the system has calculated that oil life has
been diminished, it will indicate that an oil change is
necessary. A CHANGE ENGINE OIL message will come
on. Change the oil as soon as possible within the
next 600 miles (1 000 km).
It is possible that, if you are
driving under the best conditions, the oil life system
might not indicate that an oil change is necessary for
over a year.
However, the engine oil and filter must
be changed at least once a year and at this time
the system must be reset.
Personally, I'm changing mine every 3000 miles or 1 year, I think.
over a year.
Received 2,485 Likes
St. Jude Donor '15
"In honor of jpee"
I have written so many articles on this subject ad nauseum that I can't stand to write another... for anybody! Aircraft, long-haul trucks, hotrods, street cars, muscle cars, lawnmowers... ...you name it and I've written about oil changes in them.
Seem to be respectable to me.
So, per your written words, when towing, you don't run them 12K miles, or 15K miles, but something less, right? what? 9K miles?
As to the various sites, this looks a bit like the self-proclaimed oil person expert, 'bobisthe oilguy." is it? no one knows that person's name or quals---is the last name of 'bob', knize?
While we're at it, could you quantify your bona fides? thanks.
#36
I actually heard about then found an article where Mobil-1 was tested in high mileage use. The thing that happens is metal and particulates go higher. Then, without changing the oil, they put a new filter on it and the particulates went back down to 'new' oil measures but the surprising thing is the oil actually had lubricated better than new fresh Mobil 1. This was a test over like 15-30K miles.
So, if your worried, just change the filter after three or four thousand miles and the oil when the DIC says to. The biggest thing that made a difference next to the oil filter was adding oil to maintain proper level.
#37
Location: Boca Raton Inlet, Atlantic Ocean (Floridas east coast)
I'm sure that the folks at Mobil 1 would totally disagree. You may want to send the test results to them and ask for their opinion. We heard Bill Maxwell, Senior Engineering Adviser, Exxon Mobil speak at Lime Rock last week and I believe that he stated that a 15000 interval was entirely possible at the outside.
#38
The first name of the other guy (Knize) is Russell I believe. That link is very old and very outdated.
#39
HAHAHAHA. You might want to try Googling "oil analysis" sometime before submit your next "expert" article for publication. Next Google "spell checker".
#40
Hmmm, well here is who Blackstone is: http://www.blackstone-labs.com/about_blackstone.html.
I have to say this with a bit of embarassment too :o :o :o because after looking at Blackstone.. I realise that I know (or at least have met) Jim Stark, owner ! Notwithstanding the fact that I have housed airplanes out of Fort Wayne very early in my career!! I too am a Purdue University Engineering and also Technology Graduate and probably went to school with Jim Stark crossing paths in aircraft school I bet( Also I am a A&P and ASE mechanic qualified as well) , so I can't debunk his claims or lab experiences one ioda and in fact put money on it! So, I would say that the issue could be a filter issue since metal particals actually expotentially rose in your oil.
I also have written technical ariticles for a myriad of national magazines and websites in the automotive, aircraft and "hotrod" markets for years.
First, if you are changing your oil every 3 to 5 k miles you are pouring money down the drain. And, the perfect oil performance is probably around 5k due to the PH balance of today's new oils.
I also have to respectfully disagree with one of the posters here that oil doesn't lose it's lubricity. Regardless of filtering of contaminates, oil will indeed lose it's lubricating properties due to both temperature and shearing issues. Now, full synthetics will stand up to these issues dramatically better than fake synthetics (products made from Group III base stocks) and/or just plain dino stuff!
