Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Corvette General Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
General C6 Corvette Discussion not covered in Tech Sponsored by
PFYC
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-18-2008, 11:45 AM   #1
Rapid Transit
CF Senior Member
Rapid Transit's Avatar
Default Turning AC off before shutting engine down.
I've seen many people do it. Several blocks before parking the car, they would turn off AC and let the air come through on "Vent" mode. Something about clearing the system to prevent condensation while the car is parked. What's the logic behind this practice?
Thanks,
Rapid Transit is offline   Reply With Quote
Old 07-18-2008, 11:57 AM   #2
tlcj
CF Senior Member
tlcj's Avatar
Send a message via AIM to tlcj Send a message via Yahoo to tlcj
When you turn the compressor off it gives some time for the water to drain out or evaporate from the coils. Many believe this helps in controling that funny smell when you turn the ac on at the beginning of your drive.
tlcj is offline   Reply With Quote
Old 07-18-2008, 12:00 PM   #3
It'sHerVette!
CF Senior Member
St. Jude Donor '07-'08-'09-'10-'11-'12
It'sHerVette!'s Avatar
I've never heard of this. Frankly, I don't see any value in doing it.
It'sHerVette! is offline   Reply With Quote
Old 07-18-2008, 12:00 PM   #4
patton
CF Senior Member
St. Jude Donor '09
patton's Avatar
it makes no diff.
patton is offline   Reply With Quote
Old 07-18-2008, 12:04 PM   #5
mksz51
CF Senior Member
mksz51's Avatar
OCD behavior - unlikely to help with odor issues. Leave it on auto - life's too short!!!
mksz51 is offline   Reply With Quote
Old 07-18-2008, 12:06 PM   #6
gilly6993
CF Senior Member
St. Jude Donor '08
gilly6993's Avatar
not necessary....
gilly6993 is online now   Reply With Quote
Old 07-18-2008, 12:08 PM   #7
Raazor
CF Senior Member
St. Jude Donor '09-'10-'11-'12
Support Corvetteforum!
Raazor's Avatar
I haven't run the A/C yet. Top is off ALL the time.
My mom does this with her truck. Something to do with leaking on the garage floor.
Raazor is offline   Reply With Quote
Old 07-18-2008, 12:15 PM   #8
RICH 28
CF Senior Member
RICH 28's Avatar
It absolutely works for me. My AC smelled real bad when I would start the car until I had the dealer clean it out under warranty. Since then, I push the snow flake button to stop the cooling about five minutes before arriving at my destination. I have been doing this for the past two years and still no smell.
RICH 28 is offline   Reply With Quote
Old 07-18-2008, 12:18 PM   #9
EvanD
CF Senior Member
EvanD's Avatar
I do it... more to keep the A/C from coming on as soon as I turn the key when I start it the next time. I also turn off the radio on my C4 before turning off the car so the antennae doesn't extend when I start the car...
OCD... maybe, but it works for me.
EvanD is offline   Reply With Quote
Old 07-18-2008, 12:36 PM   #10
MachAll 2005
CF Senior Member
MachAll 2005's Avatar
Call me OLD, but I've always done it.....on max blower to purge as much moisture as possible from the evaporator coils to help prevent mold from growing........thus odor.
Those that don't get it,,,,,,,,,,,,,I don't get you not getting it!!!!
MachAll 2005 is offline   Reply With Quote
Old 07-18-2008, 12:40 PM   #11
BigButtLover
CF Senior Member
St. Jude Donor '08
BigButtLover's Avatar
Location: Near Houston, Texas I like the Big Butt Corvettes
I've heard just the opposite, that it's good practice to leave the A/C on while stopping and starting the engine. Go figure.
BigButtLover is offline   Reply With Quote
Old 07-18-2008, 12:40 PM   #12
maxp
CF Senior Member
maxp's Avatar
Quote:
mine has been on auto since I bought last november. last car was a G35 and it was on auto the 3 years I drove, worked great
maxp is offline   Reply With Quote
Old 07-18-2008, 12:42 PM   #13
hawkgfr
CF Senior Member
hawkgfr's Avatar
There is a built in delay....the compressor does not run as soon as the car starts. They fixed that problem decades ago.
hawkgfr is online now   Reply With Quote
Old 07-18-2008, 12:53 PM   #14
cleif2000
CF Senior Member
cleif2000's Avatar
I used to have a locker room smell when I first started the AC. I just started the last two weeks shutting the AC down by pushing the snow flake button and letting it run for a minute or two. The locker room smell has gone away when I first put the AC on. It is worth a try if you have a mildew smell when you first start the AC.
cleif2000 is offline   Reply With Quote
Old 07-18-2008, 01:06 PM   #15
dpigguy
CF Senior Member
dpigguy's Avatar
for those of us where the temps stay high as does the humidity, following this practice helps eliminate mildew and mold plus reduces their smells on start up. owners manual on my truck even says to do this as well as leave in fresh air mode during parking to avoid mildew, mold, etc. OCD - yeah probably but it seem to work and if the OM says to do it, it can't be wrong !
__________________
"never try to teach a pig to sing ..... its a waste of your time and it annoys the pig"
dpigguy is offline   Reply With Quote
Old 07-18-2008, 01:39 PM   #16
AFVETTE
CF Senior Member
AFVETTE's Avatar
This was a common problem on the C5, Cheby released a TSB where they disinfected the vents and installed a relay where the HVAC fan sans compressor would run for a minute or two after you shut the car down.
I had the smell on my 99 and after the TSB fix my problems was solved. So at least back on the C5 this worked to vent the system and eliminate the nasty smell in the HVAC system.
I'm sure you can visit the C5 section for specifi details on that TSB as I believe it was left in effect till then end of C5 production.
AFVETTE is offline   Reply With Quote
Old 07-18-2008, 01:53 PM   #17
danl72
CF Senior Member
danl72's Avatar
Send a message via Yahoo to danl72
I do it. I don't know if it helps or not, but there is no smell. Could be because my car is only a few months old.
danl72 is offline   Reply With Quote
Old 07-18-2008, 01:55 PM   #18
Max EPR
CF Senior Member
I have been doing this for 30 years or more. Before I started this dumb procedure I had recurring bad smell problems. No more. I believe if you do get the smell and don't do anything about it that eventually there will be enough junk in the condenser that you will loose some cooling. Then it will need to be cleaned.
I have cleaned condensers with chlorine and water. Make certain that the water drain from the condenser to the ground is open. That will plug in time if there is enough junk growing in the condenser. Using maximum fan speed helps to flush the junk down the drain hose.
Happy motoring.
Max EPR is offline   Reply With Quote
Old 07-18-2008, 01:59 PM   #19
talon90
CF Senior Member
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
talon90's Avatar
The logic is that stagnant water can contribute to mold and mildew growth. Under the right circumstances (environmental conditions such as temperature and humidity) leaving the AC on until you shut the car off in your garage will leave condensation behind in the system which will mold.
By turning off the AC a mile or two prior to reaching your destination and turning the car you will allow any moisture built up to dry out and you will reduce the likely hood that you will get mold in your vent system which will produce an oder in the future. It is a documented condition and has happened in previous generation Corvettes.
Of course, outside air temperature, humidity and frequency of use will all contribute to whether or not you ever experience these problems. So of course, those that have will tell you it works, those that haven't will tell you it is A.D.D., O.C., Hogwash, wives tales and a host of other colorful descriptions for the behavior. Science will tell you it makes sense. You make the final decision.
talon90 is offline   Reply With Quote
Old 07-18-2008, 02:05 PM   #20
07c6vette
CF Senior Member
07c6vette's Avatar
Quote:
i always leave mine on when i start or turn off the car , so the vents are open...
07c6vette is offline   Reply With Quote
Reload this Page Turning AC off before shutting engine down.
Tags
ac, afteblow, air, car, conditioning, corvette, engine, guidelines, parked, problem, racing, shutting, smelling, turn, turning
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 General 239 01-18-2012 04:29 PM
? about buying a C5 gmintimidator C5 General 10 03-21-2005 02:37 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
