Ever have to change the fuel filter in the C6?
Old 07-14-2008, 12:55 PM
biskitman
biskitman's Avatar
Default Ever have to change the fuel filter in the C6?
Do you ever have to change the fuel filter in the C6? Isnt it located in the fuel tanks so how would someone change this without having the dealer do it?
Old 07-14-2008, 01:02 PM
talon90
Support Corvetteforum!
talon90's Avatar
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
The fuel filter is not considered a maintenance item. It is actually inside the fuel tank and is quite an ordeal to remove it. You should not have to replace it under normal circumstances.
Old 07-14-2008, 01:04 PM
FloydSummerOf68
FloydSummerOf68's Avatar
I dont understand why a fuel filter would be placed in the tank and not along the fuel lines where it's easier to get at like other cars.
Guess the dealers just want you bringing it in if it needs changing.
Old 07-14-2008, 01:10 PM
phileaglesfan
phileaglesfan's Avatar
A lot of GM cars are going to the filter in the tank. Some have an access panel from the trunk to make it easier.
Old 07-14-2008, 01:16 PM
danl72
danl72's Avatar
Old 07-14-2008, 03:11 PM
talon90
talon90's Avatar
NCM Ambassador
I would suspect it is because they don't need to be changed all that often. Fuel delivery systems have come a long way. Fuel in general has come a long way towards limiting the types of contaminants that may be introduced to the fuel system. Here is the image from the service manual:
(1) Fuel Fill Hose
(2) Left Fuel Tank Grade Vent Valve
(3) Fuel Feed Pipe to Engine
(4) 5/16 Inch Auxiliary Fuel Feed Pipe
(5) 3/8 Inch Auxiliary Fuel Return Pipe
(6) Right Fuel Tank Grade Vent Valve
(7) Fill Limiter Vent Valve (FLVV)
(8) Secondary Fuel Pressure Regulator
(9) Siphon Jet Pump
(10) Convoluted Crossover Hose
(11) Anti-siphon Hole
(12) Fuel Sender Reservoir
(13) Turbine Fuel Pump
(14) Venturi Pump
(15) Primary Fuel Pressure Regulator
(16) Reverse Flow Check Valve
(17) Fuel Filter
Here is the note on changing the fuel filter:
Fuel Filter
The fuel filter is contained in the fuel sender assembly inside the left fuel tank. The paper filter element of the fuel filter traps particles in the fuel that may damage the fuel injection system. The fuel filter housing is made to withstand maximum fuel system pressure, exposure to fuel additives, and changes in temperature. There is no service interval for fuel filter replacement.
Old 07-14-2008, 03:15 PM
FloydSummerOf68
I dont care if it has to be changed rarely...when it DOES need to be changed you're screwed.
Old 07-14-2008, 03:16 PM
Flyinbyu
Flyinbyu's Avatar
What a pain in the ****!
You would think they would have an inline filter like trucks/SUV's.
~Brian
Old 07-14-2008, 03:20 PM
NABLNKC6
NABLNKC6's Avatar
I can't believe that! What a pain I figured it would be like the C5
Old 07-14-2008, 03:26 PM
talon90
talon90's Avatar
NCM Ambassador
Yes you would be. The removal of the tanks is a bit of a challenge. This assembly resides behind the seats:
The C5 used a different system which was inline in the fuel feed pipe ahead of the injectors. Not sure what prompted the change. I don't know of many that needed to change the in-line on the C5 and time will tell on what needs to happen on the C6.
Old 07-14-2008, 03:28 PM
ufaj26
ufaj26's Avatar
Never have and don't plan to. Too much work. Just think when these cars get old and the next generation of restorers have to do this !!
Old 07-14-2008, 03:33 PM
bosco 08
bosco 08's Avatar
i probably won't own the car long enough to have to worry about a fuel filter
Old 07-14-2008, 03:39 PM
Rocketmanwpb
Rocketmanwpb's Avatar
This is amazing. There should have been a filter in the line between the tanks and the injectors. I have always made it a point to change the fuel filters in my cars once a year.
LS WON (10-20-2023)
Old 07-14-2008, 03:54 PM
CH-Z51
CH-Z51's Avatar
Location: The Great Pacific Northwest...........I carry a gun cause a cops too heavy.
This is why I only use top tier gasoline and a fuel system cleaner prior to each oil change. (once a year).
81VETTOM (07-16-2021)
Old 07-14-2008, 05:08 PM
paz
paz's Avatar
GM needs to realize that many Corvette owners need to tinker. Changing a fuel filter once in a while, whether it needs to be changed or not, gives us a great sense of satisfaction, not to mention the performance gains!
My wife's previous car, an Audi A4, leaked every possible fluid. Every couple of days, I had a job to do - get that car roadworthy and keep my wife safe. A few weeks ago I bought her a Cadillac STS. Now I have nothing to do. I feel so useless!
DailyDriven (11-05-2022)
Old 11-12-2009, 08:05 AM
mbracer
Cruising
mbracer's Avatar
Most GM vehicles are going to this system with the filter in the tank in my experience you will need to change the fuel pump before you need to mess with the filter, I think they are meant to be changed as a unit. Bye good quality fuel and you should not have an issue.
LS WON (10-20-2023)
Old 11-12-2009, 08:47 AM
vettedoogie
vettedoogie's Avatar
I've had a lot of cars in my life. I cannot think of more than once or twice in my life that I have really had to change fuel filters and that was in old beater '48 and '50 pickups.
To Ever have to change the fuel filter in the C6?
Old 11-12-2009, 09:18 AM
Gordon Shumway
Gordon Shumway's Avatar
That looks a lot different than the gas tank I had to change on my '65 Plymouth 40 years ago.
Old 11-12-2009, 09:27 AM
vettedoogie
Is it really necessary to remove one or both of the tanks to change the filter? Looks like a body panel and then go to the top of one of the tanks...based on the illustration.
Old 11-12-2009, 01:31 PM
4thC4at60
4thC4at60's Avatar
Received 2,921 Likes on 1,302 Posts
Originally Posted by AORoads
fuel filter in the tank for Corvette has been since the C4! but then, it was about an hour to slightly more to do.
<snip>
Huh?
Fuel filter rode inline near/above the cat mounted on the passenger side frame, there was a heat shield. Changed enough of them to know.
Now, there may have been one in the tank as well, but in almost 500,000 miles (four cars) I never had to change one.
Quick Reply: Ever have to change the fuel filter in the C6?
