Old 03-06-2015, 01:11 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
Dead Battery Can't open hood to jump start
Old 07-03-2008, 10:05 PM
smoothieusa
5th Gear
smoothieusa's Avatar
Default Dead Battery Can't open hood to jump start
Hi, need your help. My 2006 C6 convertible is stuck in the garage with a dead battery after car sat without running for just 2 weeks. Same thing happened last December except then there was just enough juice to open the car door. Anyway, there is now zero battery power so cannot open the door using the door handle or the key fob. The key fob will not open trunk to manually release driver door to then access the car interior to pop the hood release and put on the battery charger. I cannot see a key opening or trunk lock anywhere near the trunk to try the glove box / console key.
Chev road side assistance said they recommend they not send a lock smith to open door as it could damage the 2006 vette since the locks are automatic.
Without damaging the car, how can I open the door with no electrical power? Or, pop the hood to attach battery charger cables.
Thanks.
smoothieusa is offline
Old 07-03-2008, 10:11 PM
C6HOKIE
C6HOKIE's Avatar
Above the rear license plate is a keyhole to use the key to open trunk.
C6HOKIE is offline
Old 07-03-2008, 10:12 PM
overrev64
Support Corvetteforum!
overrev64's Avatar
The key opening is above the license plate next to the button that opens the trunk.
If you still can't get in, you can try to jack the car and put the charger directly on the starter terminal.
overrev64 is offline
SunsetOrangeCreations
SunsetOrangeCreations's Avatar
Location: Exhaust Commander Wireless Bi-Mode Exhaust Controllers, Innovative and advanced technology! --- Check out our website @ www.sunsetorangecreations.com
St. Jude Donor '13
Look above the rear license plate. There is a keyhole there that opens the trunk. Then use the manual release cable that is in the driver side rear trunk area to open the driver door. Then you can open the hood.
Ben
SunsetOrangeCreations is offline
Old 07-03-2008, 10:16 PM
Another Don
Another Don's Avatar
The key cylinder that you're looking for is above the rear license plate between the lights. It's near that rear trunk release button that won't work because the battrey's dead. You'll have to get down and look up to see it. The key should turn this lock that will open your trunk and inside the trunk on the left is the cable pull to manually open the driver's door.
Sounds like it's time for a new battery for you.
Another Don is offline
Old 07-03-2008, 10:18 PM
savewave
savewave's Avatar
Received 1,305 Likes on 498 Posts
CI 2-3-4-5-6-7-8-9-10-11-12
Wounded Warrior Escort '11
St. Jude Donor '03 thru '24
NCM Lifetime Member
Ben
That's the ticket.
savewave is offline
Old 07-03-2008, 10:26 PM
smoothieusa
5th Gear
Houston, we have power! Thanks everyone, you are good. The keyhole was at first almost invisible because the silver was gunked up with road crud but your comments kept me looking. Thanks again and have a great weekend!!
Is a dead / low battery typical after just two weeks of car not running? Sure would hate to arrive at airport after 3 week trip to find Corvette won't start.
Old 07-03-2008, 10:49 PM
patton
patton's Avatar
St. Jude Donor '09
when you are on the plane bring the owners manual [for the car] and READ
patton is offline
jimmymack (10-23-2021)
Old 07-03-2008, 10:54 PM
*FAÇADE*
PHOTOSHOP SPECIALIST
*FAÇADE*'s Avatar
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Thanks.
- If you have the key available, you can use it to open the trunk:
- Once you open the trunk, you can pull the door release handle located on the left side of the trunk:
- Finally, after you open the door, you can pull the hood release and charge your battery.
*FAÇADE* is offline
Old 07-03-2008, 11:05 PM
danl72
danl72's Avatar
danl72 is offline
Old 07-03-2008, 11:22 PM
ben dover
ben dover's Avatar
Location: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
There have been some complaints about a two week or three week dead battery, but mine had to sit for six weeks once and I had no problem.
ben dover is offline
Old 07-03-2008, 11:31 PM
C6NRED
C6NRED's Avatar
Originally Posted by superalpha
oh, there is a PDF of the manuals online somewhere....
Gene Culley has all of the years listed on his web site for download....
C6NRED is offline
Old 07-03-2008, 11:59 PM
Deep Silver C6 Z51
Deep Silver C6 Z51's Avatar
Had the same thing happen to my '05 once during the winter non-driving season.
If you're like me, the owner's manual was locked in the car....a little hard to refer to when the battery's dead!!!
Don't sweat it.
Usually there are a lot of friendly, helpful people on this forum that are glad to offer up a solution.
Deep Silver C6 Z51 is offline
Old 07-04-2008, 12:31 AM
cclive
cclive's Avatar
Lots of people don't know everything about everything.....we're happy to help people here....lighten up and enjoy life
cclive is offline
Old 07-04-2008, 12:36 AM
LMB 4 ME
LMB 4 ME's Avatar
Location: Boca Raton Inlet, Atlantic Ocean (Floridas east coast)
Another happy customer
LMB 4 ME is offline
Old 07-04-2008, 09:34 AM
slvr 07
slvr 07's Avatar
slvr 07 is offline
Old 07-04-2008, 10:23 AM
It'sHerVette!
It'sHerVette!'s Avatar
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Buy a Priority Start.
After you open the door with the remote cable, just press in the cigarette lighter and start the car! Works well with our '05 which still gets DBS even after all the reflashes and new batteries.
It'sHerVette! is offline
To Dead Battery Can't open hood to jump start
Old 07-04-2008, 10:28 AM
StanNH
StanNH's Avatar
Received 1,221 Likes on 411 Posts
Now that you've said that, you know what's going to happen.
StanNH is offline
Old 07-04-2008, 10:32 AM
dsdrury
dsdrury's Avatar
St. Jude Donor '08-'09
I just returned from a 23 day vacation to Florida and my 08 VY Coupe started right up! Donn in Colorado
dsdrury is offline
Old 07-04-2008, 10:39 AM
StanNH
StanNH's Avatar
Please refer to my previous post.
StanNH is offline
Quick Reply: Dead Battery Can't open hood to jump start
