HUGE, I MEAN HUGE!! Kenne Bell Announcement!!
#88
Location: ,fl.Never, under any circumstances, take a sleeping pill and a laxative on the same night.
16lb or 25lb of boost is great but i think stock internals of the engine cant handle that type of boost,forged internals would have to be a must?
#89
Former Vendor
St. Jude Donor '06 & '12
You are correct.. I personally wouldnt push a stock block past 9-11psi. But its not the psi you need to be worried about, as much as it is proper tuning.
The stock C6 kit will run north of 600rwhp in STOCK trim.
#90
do you think a good set of headers would ease the stress on the stock engine when adding boost if so what do you recomend? thanks
#91
Former Vendor
Not so much ease the stress on the block. But it will DEFINATELY ease in the efficiency on the blower. Remember: its not just about shoving the cylinder full of air/fuel. Its about getting as much of the exhaust out, and cooling the cylinder at the same time. If you dont get it out in time, you've got a contaminated cylinder.
Personally, I ONLY do 1 7/8's or larger on ANY F/I.
#94
#97
#100
Do you still need measurements from the MCM supercharger hood?
I have one on my car, it is the red 05 C6 convertible on their site.
http://www.westcoastvette.net/id177.html
