Whoooooosh, there goes the roof....
The transparent top is also made of polycarbonate but is not glued to the frame like the painted top. The problem is not the different coefficient of expansion but that the bonding mat'l did not bond to the polycarbonate. The bonding mat'l GM selected would bond to the SMC thus they changed the painted top from polycarbonate to SMC.
(supported in this thread
http://forums.corvetteforum.com/show...ighlight=shear
You know it still peeves me when I read about the roof problem. Here is the top dog Chevy and you would think the engineers did all the cold/hot testing during the development of this vehicle. I really think they dropped the ball. Where are the first rate engineers at GM ? Have they all left the company ?
Once I received my recall I bought a transparent top to replace my painted one. I couldn't stand the thought of what you described happening.
I delayed having mine fixed since it had not shown any signs of damage and I didn't want to take a chance on the dealer screwing it up. However when it was in for an ABS problem I had the top repaired and after two attempts at getting the paint right I finally just picked it up and stuck it in the box the transparent top came in until I could get the time to try and buff the marks they left in it removing the dirt that was trapped under the clear coat.
I'm glad to hear no one was injured and I hope your repair turns out better than mine.
Anbody want to give me odds...
Just to get this straight the roof on the non-Z06 car is removable correct? So it flies off even when latched in? I am aware of the flying roof problem with fixed roof Z's but apparantly the problem is inherrent in other C6's as well?
You are correct that the transparent top is polycarbonate and in the difference in the attachement method. The problem was in fact with the difference in expansion, that is fact and well documented. The difference put the adhesive in shear. This is why the tops delaminate after severe heating such as mid summer sun exposure. This was explained to me in detail by the folks from the plant.
What do I do? I bought a used c6 recently. GM does not I have this car do they? If there is a recall for my roof how will I know? Should I take it to the dealer and have them run my vin? Maybe I wshould just take it off and wait till November.
#33
The transparent top is a different animal all together. This won't / can't happen to the transparent top. With the introduction of the C6 the painted panel was changed from an SMC material (C5) to a polycarbonate to save weight due to the different size from the C5 and it saved 3 pounds. The polycarbonate has a different coefficient of expansion from the frame. During heat up and cool down cycles the panel would expand at a different rate than the frame which puts the adhesive in shear. For the 2007 model year the panel material was changed back to SMC and the problem was solved.
#34
http://www-odi.nhtsa.dot.gov/cars/pr...ls/results.cfm
#35
Hubby took our 2006 victory red to the local stealership yesterday to get the top, have the rear end looked at (the 2nd time), and other assorted issues taken care of. The top has some sort of black in the paint (dirt particles?), one corner looks like it was dropped and caused the paint to ripple....plus they got the silicone from the new gaskets all over the interior of the car....and let's not forget the greasy handprints on the inside of the driver's door. I do not understand why, if GM is replacing these roofs under a recall, they cannot get the damn paint code and have the roof panel painted at the factory, then ship it to the dealer. The local place just gets the plain roof, and then brings it to a local body shop to have it painted. What dumbarsses. I think the plan right now is to get a clear top, and pay the difference.
#36
Cruise-In VIII Veteran
A friend from work just had his top delaminate on his '06 just last week. Since I have the dual roof panel, I'm going to offer to lend him my transparent panel while his is getting replaced. He may not need it though since he has a few different vehicles to use while his top is getting replaced.
#37
MONARTOR
Just to get this straight the roof on the non-Z06 car is removable correct?** Your are Correct** So it flies off even when latched in?** YOU ARE INCORRECT. THE SOLID COVER BECAME UNGLUED AND THE PIECE LEFT THE FRAME** I am aware of the flying roof problem with fixed roof Z's but apparantly the problem is inherrent in other C6's as well?** YOU ARE CORRECT**until the 07 roof fix
#38
The fastest way for the supplier to start replacing the roof panel in the field was to supply an unpainted panel to the dealership and the dealership paints it and transfers over the hardware from the customers existing roof panel. Even if the factory did paint the panels they couldn't paint enough panels to keep up with the recall and the assembly line.
Even when the changeover was happening at the factory the panels were swapped over on a color by color basis.
Currently the factory does not paint the side mirrors, the roof panel or the headlights. All of these parts arrive painted by their respective suppliers for installation on the new Corvettes. The panel that the dealer is receiving is the same panel that would come in via the service parts organization. This way the supplier can make and inventory one, unpainted panel rather than try to anticipate which panels of which color they need to ship out.
#40
The painted top flying roof was fixed for the 2007 model year. It has never been a problem with the transparent top. If you have the transparent top you don't have anything to worry about.
