Battery died could use some advice
I have not driven my car for 2 weeks and apparently I did not leave it in reverse. Soooo, I purchased a charger and as I write this message, the battery is cooking.
My questions...
Will the fobs still maintain their memory settings? Will I have to reset the radio channels and seat settings? Does anyone have the name of the genius at GM who insisted on the reverse feature
Thanks for taking the time
My questions...
FOBS & radio should be fine, possibly you will have to re-index the windows, takes just a minute to do that. I guess your car is a '05 as only the '05 need to be shut down in reverse.
If you're looking for a charger, check out the CTEK line of chargers, either the 800 or the 3300.
The fobs don't actually remember anything. Each fob has its own permanent digital code that it broadcasts when a button is pushed and when interrogated by a car. When a fob is programmed to a car, it is just a matter of telling the car that this particular digital code is OK. The car then remembers that one and up to three more, for a total of four. The car's memory for the fob is not volatile and so is not affected by the loss of battery power. Unfortunately many other memory areas of the car are volatile....
Just got back from a 10 day vacation and my '08 battery is dead also. I am really starting to hate my Corvette, and I may have to sell it with only 800 miles on it. I parked it in 1st. Not sure if that makes a difference. (No, nothing was left on)
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Suggest you buy a "Priority Start" keeps a little juice left in the battery to start the car. Works great.
If you left it in reverse, this may have been DBS, which was a problem unique to the 2005 MN6 cars. GM did issue a computer reflash TSB which took care of this problem. If your car has not had this fix done, you'd better get it done ASAP.
