Tires Losing Pressure
Old 03-17-2008, 06:33 AM
foremaw
Support Corvetteforum!
foremaw's Avatar
St. Jude Donor '08-'09-'10-'11-'12
Difficult to make any judgments yet since its been stored quite a bit. Bring the tire pressure to 30lbs, continue to drive it and monitor it closely. It may be fine. I suspect you don't have a leak problem because it'd be pretty unusual to have leaks in all four tires.
Old 03-17-2008, 07:40 AM
avacorvette
avacorvette's Avatar
Location: Canonsburg home of Yenko Chevy (gone but not forgotten) Western PA
[QUOTE=Datawiz;1564572159]Make sure the nuts on the valve stems are tight.
This happend to me .
Old 03-17-2008, 09:00 AM
vdavenp802
vdavenp802's Avatar
Originally Posted by Modshack
Check your TPMS stem torque values...I had a light leakdown in my right rear...Bought a cheap ($20) 1/4" Harbor Freight torque wrench and retorqued all of them to 60 inch pounds. Every one of them was under spec by a goodl amount. Seems to be holding just fine now..
This is definetily something to check. I had this problem last summer with ny new 07. Drove me nuts. Also check the stem caps, and make sure the little gasket is able to make a good seal. Also check to see that nothing is jammed in the stem end itself causing a minor leak.
My tires have since stabilized, even during winter storage.
Quick Reply: Tires Losing Pressure
