100% NEW MILD2WILD Design no fobs and no visor needed
St. Jude Donor '06-'07
So here is the first new innovation since I developed the original mild2wild wireless control over 18 months ago. I am offering this system on a built as ordered basis. It's a great option for the car2u owners or owners with no universal visor system and will sell for $89. Email me to purchase pipedreams@nakidparts.com
Function:
Allows you to set your OEM bi-mode exhaust (Z06 or NPP) open 100% or to OEM operation (closed up to 3000 -3500 RPM). It has a zero current drain and will always remember the last setting. i.e.: shut down closed / starts closed.
So what is So Innovative?
It is operated by installing no switches, no wireless fobs and no need for homelink or car2u on the visor and no batteries. It uses a control that is currently in your car, is simple to reach while driving. Once installed (5 minutes) you will use your courtesy lamp switch (located just above you left knee on the dash) to activate the system. Press the button twice within 5 sec and you open you exhaust 100% of the time. Repeat the process and you turn the exhaust back to OEM operation.
Installation:
No cutting or splicing, Install the fuse tap and ground just like in the standard Mild2Wild system. Attach the sensor lead to the passenger side courtesy lamp and your up and running.
It may not be for every one but is a great option by using a control already on your car. I know some may say it will lead to having the courtesy lamps left on but once you try it you will see how simple it works It is not triggered by opening and closing the doors. This product is the result of months of design and testing and required a custom built control system.
Function:
Installation:
old m2w
Hi Ed, I have the fob operated m2w and wanted to know if you offer a credit or allowance for an exchange? Thanks and keep up the innovative work. Ken
St. Jude Donor '08-'09-'10
Your products are dynamite and the fact the you keep improving them benefits us all. Thanks, Ed.
Again this is not desgined as a replacement for mild2wild just an option. If you are intrested please email (no pms) see first post
An impressive innovation to say the least. I assume by having to push the light switch twice, the map lights do not stay on - yes? I have been on the fence about getting the M2W but you may have just pushed me off the edge!
Great improvement.
nice work
Platinum Supporting Dealership
ED YOU ROCK!
The newest Limp~2~PIMP is awesome! I cant wait to order some from you! give me a shout later this week and we'll chat! Dont forget about our corvette party that is coming up mothers day weekend!
~joshua
~joshua
