Kind of Makes You Wonder
I've read many of the threads about whether to keep Run-Flat tires or change to a non-run flat. I will need to replace my tires soon but I hadn't quite made up my mind about what to do. I must say that I've been leaning toward keeping the Run-Flats and after what I saw today, I think I'm on the Run-Flat side of the fence.
I live in a canyon and there's a single two lane road to get in and out. When I left the house this afternoon in the pouring rain (in my pickup), I passed a C5 driver working on the front wheel of his car. He had a flat and boy was he getting soaked and dirty laying on the ground. When I returned home, I passed the C5 still sitting on the side of the road on a jack and the front wheel was gone. I guess the driver couldn't fix the flat and had to take the wheel somewhere for repair.
Those Run-Flats are looking pretty good to me now for sure.
Yes, run-flats are great when there is a flat, I should now as it got me home. The negative is the cost and the hard ride.
What others have not realized also is that the Vette is low to begin with and when a tire goes flat the car will be even lower. The car does not come with a jack so if you are going to conventional tires you better be sure the jack you place in your hatch can fit under your car. Also jacking pads should either be installed or readily available.
Tire sealant, not a good idea to use due to your TPMS.
I initially was going to conventional but I think I will be staying with the run flats.
For Stock Ride-Run Flats are the way to go
I posted this on a thread regarding Firestone Wide Oval RFTs - so depending on your suspension and budget, I thought you might find my opinion to be of some assistance :
I have close to 4K miles on my FS RFTs and they provide a very smooth & quiet ride. However, I will replace them with the GY SCs before this summer because she just doesn't "feel" like a Z51 package anymore. The SCs definitely provide more grip in the turns and I love that low, choppy feeling in my Vette. The SCs inspire more confidence when I want to zip around corners & play on the freeway. If you have the base or F55 suspension, then I believe the FS RFTs would be a superior tire (cost, ride, comfort and probably comparable wear) but an inferior one for the Z51 - Hope that helps...
As a matter of fact, I slowed to a stop next to him and he motioned for me to move along indicating to me that he had everything under control. I had one of those big golf umbrellas in my truck that I was at least going to stand over him to keep him from getting so wet but as I said, he indicated he needed no help. My first thought at that time was that he had already called someone to come to the location. Since this road is about 2 winding miles before you get to where anything is, I'm sure he didn't carry that wheel down the hill.
It depends on what your reference is. The runflats I have on my C6 are not any harder than the Michelin Pilot Sports I had on my Porsche. I would bet that if I would mount Michelin Pilot Sports on the C6 they would be harder.
Unless you need the non-run flats to get maximum performance (almost impossible to achieve on the street) run-flats are good enough. Maybe 1% of all Corvettes ever made are ever driven to 100% of their capability, and most of those are road racing cars. IMO the GY SC tires will give you more performance than you will ever need on the road. And they will get you home if you do pick up a nail... I've had two nails in my C6 and it was nice not to worry about having to find instant repair. On my 2003 Z06 I crossed my fingers every time I had to drive outside the city. There are places in central TX that hardly ever see a Corvette, I don't need Bubba lifting my Vette even if he thinks he can...
I went over a decade without a flat. I've had two since I bought the Vette, one in each rear tire. I'm sticking with the run flats, and at 13K I'm within 1-2 K of the wear bars.
On the fence as to which ones though...
Something else to consider...... If the tire has to be dismounted to be repaired or if it can not be repaired and has to be replaced.
The EMTs have their disadvantages but without a jack and the possibility of having to replace a tire that is most likely not in stock I'll stick with the EMTs
