A6 Trans Learning
A6 Trans Learning
I understand that the C6 A6 transmission learns how you drive and sets up the shifting accordingly only in the "D" Mode.
1. Does the learning also affect the "S" mode when the paddle shifters aren't activated.
2. Does it learn for both drivers and change depending on which FOB is recognized and/or when the driver 1 & 2 buttons are pushed?
The concensus was that the A6 learns while you are in Drive mode, however to me that doesn't make sense as when in Drive, 1st gear is never utilized. From the time I got my car, I have used 95% of the time Sport mode and used the paddles to activate and use 1st gear. I do believe that my trans knows my driving habits.
I have had no problems and the trans works well for me when I do put it in drive and in sport mode.
1 Post
1st gear is also used from a stop in S mode if you haven't used the paddles since you put the tranny in S mode.
The only time the car doesn't start from 1st gear is when you've used the paddles. Then you have to downshift to 1st if you want to start from 1st.
The 07-08 C6 only starts in 2nd. When your in S to get it in 1st you have to paddle shift down. The reason for starting in second has to do with fuel consumption.
WARNING: the A6 tranny shifts out of 1st EARLY, at about 8 mph, so watch for it.
1st gear is always used from a stop in Drive mode. Watch the rpms on your tach and see how many times the rpms drop off as you slowly accelerate from 0 to 60.
I think you need to check as the trans always starts in 2nd gear as a gas saving feature. Sport mode without touching the paddles is in drive mode the only thing it does more then drive is it will hold the shift longer for better acceleration.
If you step on it at a stop drive mode may be kicking down into 1st gear to accelerate but under normal driving it is in 2nd gear.
However, I am challenging you to test the accuracy of what I'm saying. With the tranny in D, start from a standstill and slowly accelerate to 60. Watch the tach and count how many times the rpms drop off. Later, do the same in S without ever using the paddles. I suggest you do this in a large empty parking lot or on a deserted road.
Try it.
Are you sure about that? I don't see any reason for the 07 or 08 to be any different than the 05-06. Do the test. Slowly accelerate to 60 and count the rpm dropoffs. Do both D & S without ever touching the paddles. I'll bet you'll learn something.
If you've used the paddles since shifting to Sport mode, the car will start off in 2nd gear unless you manually downshift to 1st. Shifting back to Drive, Neutral, Reverse, or Park and then back to Sport will reset to the non-paddle mode and the car will automatically start off in 1st again until you next touch the paddles.
Sorry, you're wrong. When in Drive, the car always starts off in 1st gear. Always. Every time. Same in Sport mode unless you've used the paddles.
Also when it comes to learning here is what the manual says: While in automatic SPORT MODE (S), the transmission computer determines when the vehicle is being driven in a competitive manner and will select and hold the transmission in lower gears and have more noticeable upshifts for sportier vehicle performance.
Nothing about learning in D mode
Received 1,013 Likes
2016 Corvette of Year
2015 C6 of Year Finalist
Since I got tuned Friday my car when starting in paddle defaults to 1st gear now, it used to start in 2nd unless put in 1st, now it automatically goes to first. But I believe also that in D it starts in 1st
Gotta agree with Shopdog. Mine starts out in first everytime, both D & S. I also had my shift points changed in D mode (when I had it tuned) so that it shifts at 2000 rpm in each gear. Makes for much more sportier driving. If in fact the tranny does learn in D mode, making the shift points a little sportier may help out S mode performance. Anyway, for me in D with the higher shift point it shifts from 1st to 2nd at 14 mph. When in S it shifts from 1st to 2nd at around 9 mph (stock shift point). Pay close attention when you are driving and you'll feel it.
