How long can a Corvette last?
Won't last as long
I've had a 67 corvette since 1968 and did just about what you described. Since things fail with time, I've had to replace several items but most are available because someone bought the dies or somehow found ways to make the parts again (like my side exhaust pipes). However that will be much more difficult in the future for the computer components in the current corvettes. The computer chip sets will just not be practical to remanufacture. So for those components, you will just be able to get them until the original supply is gone. Hopefully that will be many years but I have difficulty believing my 2005 will still be completely operational in 40 years like the 67 is, even with the same care.
For what it is worth, a GM Corvette engineer that I met told me the LS2 engine in the C6 is stress tested to 200,000 miles. (Presuming of course you follow recommended maintenance.)
As others have stated, you can always replace parts, and if parts are available, I would think 200,000 miles and 30+ years are easily within reach.
HOWEVER, the rub is -- "if parts are available". Modern cars, and *especially* the C6, are increasingly depending on specialized proprietary electronic modules. It used to be standard practice for GM to only keep parts available for the past 11 model years, but I've seen examples of parts being discontinued sooner than that.
At some point, the determining factor in keeping a car running is the ability to scavenge still-working critical parts from junkyards. The question is -- is that point 10 years from now? 15? 20?
The advantage to mass-producing the C6 is that hopefully the large production numbers will ensure a good supply of used parts for a very long time.
Location: The Great Pacific Northwest...........I carry a gun cause a cops too heavy.
1 Post
A good friend in my Corvette club has a 63 that he has owned since
1965. It was his DD for about 20 years and he put over 100,000 miles on it the first 3 years he owned it. The car now has close to 300,000 miles on it, the engine is origional and the only major engine work has been valves and timing chain. The old vette is pretty tired now and could use a total resto but still looks really good and is usable. It will get a redo someday, he just finished a frame off on a 61 he just purchased.
How long do you think a Corvette can last, assuming that you take the best possible care of it without being obsessive, drive it regularly but lightly, have no accidents or major incidents, and still keep the original vehicle intact (meaning, all stock parts when replaced, and not more than 60% of the parts having been replaced throughout the life of the car). At what mileage/age do you think there would be no hope of a Corvette to keep running decently?
Since there still are 1953's around, I would say that long...
Received 1,269 Likes
2021 C1 of the Year Winner - Unmodified
2020 C1 of the Year Finalist - Unmodified
2016 C1 of the Year Finalist
Well, let's see . . . using actual existing cars rather than opinions, we know for a fact that more than a few of the 300 original 1953 Corvettes still exist. Granted, some have been restored, but they have survived and still exist and almost all of the survivors are in a driveable condition. So we know that a Corvette can last at least 54 years, because they actually have. Not sure what the upper limit would be - although if the best existing 1953's are well-maintained (and there's every possibility that they will be), they could theoretically last almost indefinitely with routine replacement of worn-out parts.
#33
But I also agree that the newer Corvettes will have a harder time surviving than the older ones due to proprietary parts. There are going to be a limited number of BCMs and once those are in working cars and GM has moved on and no more are being produced, it is going to be harder and harder to find one for a replacement.
#34
1 Post
That's hard to say exactly, but I would say it can last a very long time,
probably more than 25 years, if properly taken care of and maintained.
Of course, a lot depends on how often you drive it (mileage-wise), etc.
I have an '84 911 and it's still going stong....still looks good too.
#36
The life of a Vette is only limited by the maintenance and care you put into it. Obviously, rust isn't an issue with the body, so it all comes down to how much abuse you give and how well you maintain it. If you take care of it, it will easily outlast you.
#37
St. Jude Donor '06-'07-'08-'09-'10-'11-12-'13-'14-'15-'16
http://astore.amazon.com/variousname...ail/0684808544
One thing about America, if there's a buck to be made somebody will figure out how to re-engineer it.
The key word here desirable, which Corvettes will always be. But if you have a 2007 Buick La Crosse
and twenty years from now your computer chip goes out, your probably going to be S.O.L.
#39
If his dealer was in Arizona then I even know which one it might have been lol. I got the same sell from the dealer where I bought my vette. The dealer was pushing the rustproofing option until I pointed out the fact that the vette was made of fiberglass, upon which he moved on to the next item on his "fleece the customer" checklist.
#40
