z51 oil change
A better interval is every other oil change or 10K miles whichever comes first. The best method is to simply feel the fitting seal, or visually inspect it to see if it's plump with grease...if you can feel or see that the seal has grease within, then greasing is not required. Overgreasing will lead to grease leakage from the seal and a mess on your rear wheels.
That's where you use the oil with the Z51 logo on the bottle.
BTW, I understand that some if not all FE3 cars also have these greasable end links.
But I agree, not needed that often - 10,000 miles is probably overkill. And don't use a lot of grease - just a pump or two.
Unless you do a lot of tracking, you will likely find that lubing the rear toe links at EVERY oil change is unneccessary and will create a mess for you.
For your information the z51 package does have different parts,than non z51 and the rear toe links need to be maintained.
What does that have to do with emblems?
Enjoy your Thanksgiving
1 Post
If you don't have an intelligent answer to the question posed,move on.Why do idiots have to get into the z51 envy mode anytime one is mentioned?
It is exactly people like you I was referring to.All I did was use the resources of this forum to get an answer to a question I had about services specific to my z51 option.Many members gave me good info.Yet you chose to tell me why didn't I read the manual .I appreciate your very helpful advise.Then you get into thet old topic about the z51 is nothing special blah blah.Ifyou feel that strongly start your own thread and get off mine.
Engine Oil with Filter
6.0L Engine 5.5 qt
6.0L Engine Performance Package (Z51) 6.0 qt
7.0L Engine 8.0 qt
And, under "Maintenance Footnotes", footnote (b), in Section 6, Maintenance Schedule (page 6-7 in 2006):
Visually inspect front and rear suspension and steering system for damaged, loose, or missing parts or signs of wear. Inspect power steering lines and hoses for proper hook-up, binding, leaks, cracks, chafing, etc. If you have the Z51 performance package, lubricate the outer ends of both rear toe-links.
Check your owner's manual and get back to us. Ya got to watch those footnotes...they'll nail ya.
1 Post
I'll say it again read the manual its the best source of information regarding service to your car. Not CorvetteForum.com
St. Jude Donor '09
my 2006 owner's manual says:
Scheduled Maintenance
Service Maintenance II
Inspect suspension and steering components. See footnote (b). •
(b) Visually inspect front and rear suspension and
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,837 Likes
2015 C7 of the Year Finalist
Maybe they've edited Z51 out of the 2008 manuals, but the 2006 Owner's Manual clearly indicates special attention for Z51 in the "Capacities and Specifications" section (page 5-101 in 2006):
6.0L Engine 5.5 qt
7.0L Engine 8.0 qt
6.0L Engine 5.5 qt
7.0L Engine 8.0 qt
Damn, it says the same thing in my 07 manual. Since I've read the manual and have seen the information on here, I would say that there if fact IS something different about the Z51 oil change and lube requirements as compared to the F55. Since I have the Z51 option, it is important to note that there is additional oil required AND the 2 lubrication points that need maintenance.
