Free shipping on Halltech Venoms!!!
Supporting Vendor
St. Jude Donor '06-'07, '13, '15
All of our Halltech Venoms are on sale and we are offering free shipping in the Continental US.
More info listed below....In stock and ready to ship...
Corvette C6 Intake....
This is one of the best intakes you can get for your 05-07 C6 (Non Z06)....
Thanks all,
Jim
Thanks all,
Jim
Supporting Vendor
Different MAF.....this is the one you want for the 08's...
http://www.southerncarparts.com/corv...ais-p-400.html
Jim
Jim
I have a few questions, not sure if you can answer, but here goes....
Does the Halltech require any special cleaning product or "recharging"?
Does that air diverter that it can work in conjuction with [I think it was called the Corvette Air something] referenced in the ad require cutting into the car or is it a bolt on?
Does the air thingy funnel air (and H2O?) right to the filter or does it funnel it into the area below the filter?
thanks for your help!
Supporting Vendor
As far as cleaning, usually every 20k miles you can either replace the filter or you can clean it. To clean, all you need is a K&N filter recharge kit. It can be picked up at any local Pep Boys or Auto Zone.
The Vette Air does require cutting of the black shroud, but has nothing to do with the Halltech. They are totally separate products and can bu used with or without one another. The Vette Air does help with getting fresh air to the filter, but do to the way it is installed, I cannot see it scooping up water unless the front end of the car has water up pas the front fascia...
Let me know if this helps or not...
Thanks,
Jim
I have a halltech stinger for my 06. Do you guys have any extra smooth couplings laying around? I have the stock accordian looking thing on mine and it looks awkward.
I have an LS3. How does the filtration capability of this halltech compare to the stock "shop towel looking" filter media. I have seen problems with turbo charged engines and folks using "k&n" stle filters. ie, they pass more air AND dirt under boost.
I would love to increas HP, but not at the expense of more dirt.
Chris
Chris
Supporting Vendor
Chris
Chris
You want this one for the LS3....
Nothing is getting past it...
Halltech LS3 Killer Bee Intake
Thanks,
Jim
Supporting Vendor
If you're sure you want a Halltech (personally, they're my top choice), it's going to come down to whether you get a Killer Bee for the Z06/2008 LS3, OR a Venom for your '05-'07 C6 non Z06. If you think it'd help, feel free to give us a call at 678-463-4739 and we'll be glad to talk it over with you.
Thanks,
Dave
Thanks,
Dave
Supporting Vendor
St. Jude Donor '09
Chris
Chris
http://www.halltechsystems.com/category_s/43.htm
Estimated HP increase is 9-12 HP over the stock airbox. Your Corvette intake and exhaust system are two of the easiest ways to add Horsepower to your Corvette. Don't skip on either one, get the best you can afford.
Installation Instructions are located here.
Free domestic shipping for a limited time.
14 to 16 RWHP
Killer Bee ISO 5011 Filter
Velocity Stack Flange
Smoothbore Silicone Connector Hose
15 minute Installation
Uses Stock Delphi MAF Sensor
Requires NO Reprogramming
Matches the LS7 Airflow
+3 RWHP vs. the C6 Stinger
Supporting Vendor
Just a mistake.....
Should read 9-16hp....all depends on the dyno, environmental surroundings at the time of the run, and car....
Sorry,
Jim
Sorry,
Jim
I'm curious about the hp increases stated on the website. I copied the description from your website. First it states 9-12 hp gains and then it states 14-16 RWHP gains. Can you explain why the 2 numbers are different? I'm confused. The information below this line is from the website...
14 to 16 RWHP
14 to 16 RWHP
