Window Squeek?
Window Squeek?
I've been battling squeeking which seems to be getting worse in my 08 vert. It seems to be behind my left shoulder but more and more I'm thinking its the windows squeaking, because of how it gets pressed against the weather stripping or something like that.
Has anyone experienced this? Since there is no backseat, its hard to have someone listen for the noise while you drive.
Well I was out driving just now, dropped the window a bit and the creak goes away, raise it up and I hear the whole door creaking. do you think lube will work, what kind do I use?
Hi,
First post here, so lets make it a good one
I've been dealing with this same problem. Picked up a new vert a couple of weeks ago. Depending on how the top goes up and down, seems to change whether it creaks worse or not. Try putting the top down and up again, probably make it a bit better.
Next step I guess is to try lubing the weatherstripping as mentioned by a number of other people. I'm not sure what kind to try though, have seen some type of spray on silicon spray used on weatherstripping before. I think I will probably try this first and then go from there.
Location: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
it's from body flex. i've got the same issue on my '05 coupe. changing the tops doesn't resolve it. if you lube the weatherstriping it will take care of it for a bit, but it will return. i've been thinking about the 'abs of steel' to see if it reduces the body flex enough to kill the squeek.
Stop into any auto parts supply store and pick up a tube of silicone grease/dressing. Lubricate any rubber surface that touches the glass. Then lubricate the stripping and pins on the roof. Apply generously and wipe off any excess that winds up on the top of the windows. You'll have to do this every few months, but it will eliminate almost all of the noise.
I noticed the other day if the car is out in the sun all day that it doesn't seem to squeak. Maybe the rubber heats up and stops the squeaking. I am going to see if I can get som lubricant and see if that helps.
autoparts store had no spray silicone. Hubby gave me some silicone thats used for pool orings and such and I put a little of that on. Will see what happens tomorrow. Not sure if I used enough but didn't want to ruin anything. Very greasy stuff.
