Seat Belts Flapping?
Is it me or does anyone else's seat belt on the passenger side make a whole lot of noise when the window's down or top off? I have to buckle it when no one is riding with me and the window's down or roof off to stop the noise (flapping).
I've found that if I raise the pax window about an inch and a half to two inches, it will block the wind from causing the seat belt to flap.
Another solution would be putting a good looking babe in the pax seat.
Uh well nevermind it's probably against the rules anyway.
Former Vendor
Buckling is the solution, but my problem is that I always forget to buckle it before I take off... I need to tie a string around my finger or something... because otherwise I'm then flying happily along some backroad (where there is no good safe place to pull over) and I need to endure this loud flapping for the next 20 minutes or more ... this has happened to me way more times than I care to admit ... and it's way too dangerous to attempt to buckle while driving.
The aftermarket needs to come up with a new decal for the interior... perhaps for the visor... "buckle passenger seatbelt before take off!" Actually, this might be a good message to program into the DIC greeting!
Same here. No big deal to buckle it, though.
I was thinking about this a couple of weeks ago. I would think that Pipedreams (Ed) could come up with some sort of seatbelt "clip" that could be attached to the panel behind the seatbelt (maybe with a double sided adhesive).
