Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Corvette General Discussion
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
General C6 Corvette Discussion not covered in Tech Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-16-2007, 08:56 PM   #1
kilr4d
CF Senior Member
kilr4d's Avatar
Default What is an FE1 "Soft Ride" Suspension? Build Sheet Attached.
Did a forum search with no results..build sheet specifies FE1 - Soft Ride Suspension.
Quote:
VEHICLE BUILD
Merchandising Model :
1YY07 -2005 CORVETTE COUPE
Gross Vehicle Weight Rating :
1666 kg (3674 lb)
Build Date :
03/15/2005
Build Plant :
155Y
OPTION CODES
AAB - MEMORY PACKAGE
AG2 - SIX-WAY POWER PASSENGER SEAT
AJ7 - AIR BAGS, FRONTAL & SIDE IMPACT, DRIVER & PASSENGER
AQ9 - ADJUSTABLE SPORT BUCKET SEATS WITH LEATHER TRIMMED SEATING SURFACES
BGR - BOWLING GREEN PLANT
CF7 - REMOVABLE ROOF PANEL
CJ2 - AIR CONDITIONING-ELECTRONIC DUAL ZONE
DD0 - ELECTROCHROMIC MIRRORS INSIDE REAR & LEFT OUTSIDE REAR
DD8 - OSRV
DL5 - ROADSIDE SERVICE INFORMATION DECAL
D42 - LUGGAGE SHADE & PARCEL NET
E2C - ORDER TO DELIVERY - EXPEDITE
FE1 - SUSPENSION SYSTEM-SOFT RIDE
FE9 - 50-STATE EMISSIONS
GU6 - REAR AXLE 3.42 RATIO
IL3 - TRIM INTERIOR DESIGN-AQ9
JL5 - CONTROL MANUAL TRANS, 1ST TO 4TH GEAR SKIP SHIFT
JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM
KA1 - HEATED SEATS
K63 - 110 AMP GENERATOR
LS2 - 6.0 LITER SFI V8 - 400 HP
MM6 - 6-SPEED MANUAL TRANSMISSION
MN6 - 6-SPEED MANUAL TRANSMISSION
NK4 - LEATHER WRAPPED STEERING WHEEL
NT9 - FED EMIS SYS, TIER 2 PHASE-OUT
N37 - STEERING: POWER TELESCOPING& MANUAL TILT STEERING COLUMN
QG7 - POLISHED ALUMINUM WHEELS
R6P - SPECIAL PAINT
R9U - GM ACCESS - AUTOBOOK IDENTIFIER
R9Z - POMS EXPEDITE - SOLD ORDERS
SLL - SOLD ORDERS
UE1 - ONSTAR SYSTEM INCLUDES 1 YR SAFE & SOUND
UG1 - HOMELINK TRANSMITTER
UJ9 - LOW TIRE PRESS. INDICATOR
US3 - ANTENNA DIVERSITY
US9 - RDS AM/FM STEREO W/6-DISC IN- DASH CD W/MP3 PLAYBACK, BOSE PREMIUM 7 SPEAKER SYSTEM (REPLACES STD/OPT/PKG RADIO)
UV6 - HEAD UP DISPLAY
U2K - XM SATELLITE RADIO - OVER 130 CHNLS OF DIGITAL ENTERTAINMENT SERVICE FEE EXTRA.1ST 3MOS.INCL
U52 - ELECTRONIC INSTRUMENTATION
U65 - SPEAKER SYSTEM 7, PREMIUM
VA5 - ENGLISH LANGUAGE LABEL
VDD - VEHICLE INFORMATION DVD
VK3 - LICENSE PLATE BRACKET
VM3 - CONSUMER INFORMATION LABEL
V73 - STATEMENT OF VEHICLE CERT.-U.S. / CANADA
XFV - FRONT TIRE - P245/40ZR18
YFX - REAR TIRE - P285/35ZR19
1SB - PREFERRED EQUIPMENT GROUP AIR BAGS, FRONTAL & SIDE IMPACT DRIVER & PASSENGER LUGGAGE SHADE & PARCEL NET 6-WAY POWER PASSENGER SEAT ADJUSTABLE SPORT BUCKET SEATS W/PERFORATED LEATHER INSERTS HEAD UP DISPLAY HOMELINK TRANSMITTER MEMORY PACKAGE AUTO DIMMING ISRV MIRROR W/COMPASS & DRIVER OSRV MIRROR HEATED SEATS RDS AM/FM STEREO W/6-DISC IN DASH CD W/MP3 PLAYBACK, BOSE PREMIUM 7 SPEAKER SYSTEM (REPLACES STD/OPT/PKG RADIO) PWR TELESCOPING STEERING
1SZ - PREFERRED EQUIPMENT SAVINGS
L9U - LEMANS BLUE
36I - LT STEEL GRAY INTERIOR TRIM
363 - STEEL GRAY LEATHER TRIM SEATING
kilr4d is offline   Reply With Quote
Old 07-16-2007, 08:58 PM   #2
ttomczak
CF Senior Member
St. Jude Donor '06
ttomczak's Avatar
You have the standard suspension for the C6, it only means you did not pick either F55 (the mag ride) or Z51 (the performance ride).
Still a great car!
ttomczak is offline   Reply With Quote
Old 07-16-2007, 09:07 PM   #3
AFVETTE
CF Senior Member
AFVETTE's Avatar
Quote:
Still a great car!
What's nice about the FE1 or "base" suspension is how easily it can be upgraded in steps to be exactly what you want/need. Many replace the sway bars first with either the Z51 or Z06 bars for about $200. They are plug and play and make a huge difference in how the car corners. Then if you find you still want/need more you can spend another $300 and replace the shocks with either the Z51 or Z06 shocks. And at this point if you still want MORE handling you can replace the springs.
So for about $1000 you can tailor the car to suit your EXACT desires.
This is what I did with my 99 coupe I owned several years ago. I bolted on all the OEM Z06 suspension bits. I love how the car responded and felt.
Tom
AFVETTE is online now   Reply With Quote
Old 07-16-2007, 09:28 PM   #4
The Clevite Kid
CF Senior Member
St. Jude Donor '08-'09-'10-'11-'12-'13-'14
Support Corvetteforum!
The Clevite Kid's Avatar
HOWEVER . . .
Tom is a serious road-course driver, so his needs may not be exactly the same as yours.
But Tom is right-on when he describes the base suspension as a fine starting point for whatever you want to do. And it will take good care of you while you are deciding.
I have the FE1 suspension on my convertible, and have added the Z51 bars and bushings. Next will be the Bilstein HD shock absorbers, and then I will have the classic "shopdog" configuration.
Good luck with your C6.
__________________
The Clevite Kid 2006 C6 Vert - MN6 - Silver and Red - R8C
"May the Torque be with you."
The Clevite Kid is offline   Reply With Quote
Old 07-16-2007, 09:39 PM   #5
kilr4d
CF Senior Member
kilr4d's Avatar
Quote:
Originally Posted by clevitekid View Post
HOWEVER . . .
Thanks to all. Don't have it yet...but I will get one soon.
As an aside, "Soft Ride" is the WORST name ever for a sports car suspension.
Old 07-16-2007, 11:37 PM   #6
C-INRED
CF Senior Member
St. Jude Donor '06
C-INRED's Avatar
Quote:
That's probably exactly why it's called that....they want you to upgrade and spend more money!
C-INRED is offline   Reply With Quote
Old 07-16-2007, 11:42 PM   #7
sabooher
CF Senior Member
This is what I plan on doing with mine as well.
Haven't decided if I want Z51 or Pfadt's though and whether to go with Bilstein's or Koni's.
Decisions, decisions.
sabooher is offline   Reply With Quote
Old 05-11-2012, 09:03 AM   #8
Frus
Junior Member
Frus's Avatar
Hello, help me please, how to define suspension type fe1 or fe3?
vin code: 1g1yy24u455121069.
Frus is offline   Reply With Quote
Old 05-11-2012, 09:42 AM   #9
Boomer111
CF Senior Member
Boomer111's Avatar
=kilr4d;1561103804]Thanks to all. Don't have it yet...but I will get one soon.
As an aside, "Soft Ride" is the WORST name ever for a sports car suspension.[/QUOTE]
I agree but in reality the name fits the ride, which is the reason I replaced mine with the bigger sways and the FSD Koni shocks.
I found the standard Z51 set up to harsh for street only.
Boomer111 is offline   Reply With Quote
Old 05-11-2012, 09:47 AM   #10
boraxman
CF Senior Member
I put on the DRM Bilsteins recently and they made quite a difference over the stock z51 shocks, much better/
boraxman is offline   Reply With Quote
Old 05-11-2012, 10:10 AM   #11
GCRoberts
CF Senior Member
GCRoberts's Avatar
Greg Roberts
Hmmmm.....I was told FE1 was the alignment of the front wheels. I'll have to paraphrase as this was told to me by my salesman...as told to him by the mechanic. NOTE: This was the result of him getting back to me on a specific question regarding tire wear.
I take NO credit or blame for any inaccuracy below...and will be happy to be corrected if it's all wrong.
The wheels are aligned in a way where the top of the tires are angled in towards the top....imagine a trapezoid. There is a range of FE1-FE5, where FE1 is the least aggressive and FE5 is the most aggressive. The higher numbers will wear the tires faster. The higher end models (ZR1) would be setup as FE5 by default....while the base model Corvette would be setup as FE1 by default. My midrange GS Convertible would me FE3 by default. Customers are free to request modifications to the alignment at any time.
Can anyone confirm or deny this information?
GCRoberts is offline   Reply With Quote
Old 05-11-2012, 10:16 AM   #12
Frus
Junior Member
Frus's Avatar
I have RIDE & HANDLING SUSP(FE2). Can i chage it to fe1 or fe3 ?
Old 05-11-2012, 10:23 AM   #13
Wayne O
CF Senior Member
Wayne O's Avatar
I believe that's inaccurate. There may be variations in the alignment between the various ("FEx" designated) suspensions but the designation itself does not refer to the alignment....it refers to the actual suspension hardware.
__________________
2005 Corvette C6 Coupe
Magnetic Red Metallic II/Cashmere, MN6, 1SB, F55
Lingenfelter 403 Conversion, LG Pro Headers (coated), Corsa Sport Exhaust, Lingenfelter CAI, Accusump, LGM Coil-Over Suspension & Bump-Steer Kit, T1 Sway Bars, Pfadt Control Arm Bushing Kit, Elite Eng. Tunnel Plate & Oil Catch-Can, SKF Racing Hubs/Bearings, AP Racing Brakes, DRM Brake Ducts, Custom Roll Bar, Sparco Seats, Wide-Booty, CCW C10 Wheels,
Setup: LG Motorsports
Thanks to: 21st Century Muscle Cars
Wayne O is offline   Reply With Quote
Old 05-11-2012, 10:25 AM   #14
el es tu
CF Senior Member
el es tu's Avatar
FE1 has the softest shocks (the bodies are even thinner than the other shocks)
Sway bars are thinner than the rest at 25.5mm front and 17.5 in the rear
Springs are 420 up front and 657 in the rear
the biggest issues with the fe1 suspension are body roll and brake dive but its still a decent setup - people have successfully competed using the base suspension
Quote:
Yes everything is interchangeable. Fe2 is mag shock though so youre either going to need to keep the shocks, use "simulators" or a tech 2 reprogram
btw the fe2 springs and sways are the same as fe1
el es tu is offline   Reply With Quote
Old 05-11-2012, 10:34 AM   #15
JoesC5
CF Senior Member
"Can anyone confirm or deny this information?
Your salesman and mechanic are wrong. The different RPO's, FE1, FE2, etc are the designations for the different suspension packages. Being that the FE1 is the softest ride and the the ride gets stiffer as the number goes up, the alignments are different.
MY Z06 has the FE4 suspension(larger sway bars, stiffer springs, tighter valved shocks) then the FE1, so it does have more negative camber then the FE1 suspension. To get better wear from my tires, I had the camber changed from a -1.2 degree to a -0.9 degree. The alignment is different but it still has the same sway bars, springs and shocks, thus is still a FE4 suspension. Even if I reduced the camber to -0.5 degrees, the spec for the FEF1 suspension, my Z06 would still have the FE4 suspension with the stiffer springs, larger sway bars, etc.
From GM's ordering guide..
"FE1 Suspension, 4-wheel independent,
includes transverse composite
springs"
"FE4 Z06 Performance Package, 4-wheel independent, includes
transverse composite springs, power steering, engine oil, axle
and transmission coolers, stiffer springs and stabilizer bars,
specific shock absorbers, larger brakes with 6-piston front and
4-piston rear cross-drilled rotors and specific tires"
"FE5 ZR1 Performance Package, 4-wheel independent, includes
Magnetic Selective Ride Control, larger Brembo ceramic brakes
with cross-drilled rotors and specific tires"
As you can see the different suspension packages have different hardware and the alignment is just one part of the package, that is easily changed.
JoesC5 is online now   Reply With Quote
Old 05-11-2012, 10:37 AM   #16
Frus
Junior Member
Frus's Avatar
Thanks, I from Russia and badly write on English.
Fe1 and Fe2 springs identical? Where it is possible to buy that the check did not?
Old 05-11-2012, 11:01 AM   #17
TMyers
CF Senior Member
TMyers's Avatar
Yes springs are the same.
TMyers is offline   Reply With Quote
Old 05-11-2012, 11:07 AM   #18
TMyers
CF Senior Member
TMyers's Avatar
Simulators are hit or miss on the C6. Works for some and not others. Also it can be argued that it is the most expensive way to make the change.
Old 05-11-2012, 11:15 AM   #19
el es tu
CF Senior Member
el es tu's Avatar
Quote:
That doesnt surprise me - same reason Id never trust O2 simulators over a decent reprogramming of the system...
Old 05-11-2012, 11:34 AM   #20
Frus
Junior Member
Frus's Avatar
Without reprogramming that will be? Check?
Reload this Page What is an FE1 "Soft Ride" Suspension? Build Sheet Attached.
Tags
2007, building, c6, car, chevrolet, corvette, fe1, fe9, ride, soft, sports, standard, supensoin, suspension, system
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
FS 2008 Coupe rrexecutive C6 Corvettes for Sale 2 03-10-2014 10:10 PM
For Sale: 2011 ZR1 3ZR pkg Mint and only 6,685 miles. call3012124420 Mike@Criswell C6 Corvettes for Sale 0 07-16-2013 02:09 PM
F/S 2005 Z51 Yellow, $26,500.00 postmaster C6 Corvettes for Sale 0 06-09-2013 11:21 PM
FS: 2007 Le Mans Blue Corvette Convertible in KY - $38,800 Keith@VetteFinders C6 Corvettes for Sale 0 05-27-2013 06:45 PM
For Sale: 2006 Corvette Convt. Lemans Blue Metallic Z51..Mike Furman 301 212 4420 Mike@Criswell C6 Corvettes for Sale 1 08-20-2012 07:28 AM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
