2005 Repair Log
Received 4,684 Likes
2005 Repair Log
Well I just had my second problem with my '05 :
* Read End Chatter - repaired at 12K (aprox.) miles
* Passenger's Power Window Regulator/Motor fails at 30K miles
All in all, I do not believe that is a bad repair record for a car with over 30K miles. How are the rest of the '05's doing? If you have an '05, please post your problems (if any). Thanks!
MONARTOR
my 07 has had 5 differential fluid changes, new clutch pack and new differential.. 13+K... now I gotta worry about the window regulator
05 with 23,500 miles
Rear end chatter with fluid change, clutch pack in rear end, broken right rear axle (done by a valet), radio swap...
Not great compared to a Japanese car...But I love the Corvette.
05 Vert with 18,000 miles:
Fuel level card replacement (warranty)
New tires @ 13,000 (F51) (wish it was warranty!)
and that's about it.
Why doesn't Consumer Reports ask me about frequency of repair?
CF Senior Member
I consider my 2005 C6 to be extremely reliable and trouble-free (albeit with a different engine in the car)....
- OnStar antennae module replaced when I first picked-up the car
- roof panel replacement
- fuel door actuator replaced
- I had one other minor problem which I do not attribute to GM
I sometimes read other people knocking GM products....my 2001 3/4 ton, 496 cu in, 4x4 Suburban has been 'bullet-proof.' With 100,000 miles on the odometer (with routine maintenance) I've only had to replace the water pump.
Only had my 05 for a week. Past record shows a door handle replace and a rear hatch adjustment, that's all. But I will tell everyone this, if you have the m6, change your clutch fluid! Mine has 15k miles and I used a turkey baster to drain and refill my fluid. Do this about six times, pumping the clutch between fills untill the fluid is clear. I used synthetic dot 4 and my clutch is so much smoother and eaiser to shift now.
05 Coupe 56,800 miles
fuel card problem at 5500 miles
set tires at 34,300
Even though I will need tires again shortly everything think about this car is great.
set tires at 34,300
18,000 miles , 2.5 years old.
Replaced turn signal harness,
Repalce parking brake lever,
2 check engine lights, (PCM, Oxy Sensor),
Repalced front brake pads (squeeking)
Replaced radio (couple presets not working)
All issue's minor, the car has been great.
19,000 miles now
Replaced factory radio for reconditioned one because of terrible reception
Recall for Targa Top
Replaced one DRL before 1,000 miles.
Funky odor from Air Conditioner
Replace fuel door cable- "check gas cap"
Replace "Shift to Park" sensor
2005 Coupe ~13,000 miles
Fuel sensor card replaced
Fuel transfer line replaced
Air bag serviced x 5
Dead battery x 1
Rear diff chatter serviced
Roof foam application
Been a sort of high maintenance car, but I love the damn thing!
Dead battery x 1
2.5 years, 18,000 miles:
Replaced DRL at 2000 miles (under warranty)
Roof panel recall -- foam adhesive injected
Rear end chatter -- replaced fluid (under warranty)
All minor problems --- a great car!
Ultimate Keyboard Warrior
2 years, 7600 miles:
Replaced failed XM antenna
30+K miles.
Bolt fell out of rear diffuser. Replaced it myself.
Brake line recall.
Roof replaced under recall.
Driver's power seat and telescopic steering column inop (2 attempts to get it
fixed right). Replaced seat module.
Driver's window replaced (chipped on weatherstrip rivet).
Driver's weatherstrip rivet replaced.
Silver shifter surround plate paint peeling, replaced.
A/C fan button cracked, replaced.
Passenger door exit button cracked, replaced.
Rear axle chatter, replaced fluid.
Start button cracked, replaced.
Start button fell into dash, fixed it myself.
All A/C control buttons sticking, replaced control module.
Both seat heater buttons sticking, replaced.
Driver's door panel loose, replaced missing retaining clip.
Driver's door and window out of alignment, window indexing outside of roof
channel.
Driver's door exit button cracked, replaced.
Hatch shocks weak, replaced.
Nav radio needs replacement, screen goes black intermittently (months still waiting
for new unit on "National Backorder"?).
Silver shifter surround plate cracked, replaced again.
Telescopic steering column noisy while moving, dealer lubed, still noisy.
Center console lock broken, linkage repaired.
Rear axle chatter again, replaced left cover seal.
Emergency brake handle vinyl scratched from touching open center console door. *
Driver's door window still out of alignment after 3 repair attempts. *
Carpet does not meet center console. *
Rear axle chatter third time. *
* haven't taken car in for these problems yet.
Brake line recall.
channel.
