What Octane do you burn(merged)
05-17-2007, 01:35 PM
Always use 93 but, will not purchase at an "Off Brand" station, e.g., Race Tack, Speed Way, Daves Local Stop and Rob, etc.
05-17-2007, 01:38 PM
Cruise-In VIII Veteran
Quote:
Originally Posted by
filmelf
91 is the best you can do in CA, unless you buy racing fuel.
Never had problems. But if premium was 93 like it used to be here, that's what I'd use.
BP/Amoco, Exxon or Shell
93
05-17-2007, 01:40 PM
I always use the premium grade, usually 92.
05-17-2007, 01:47 PM
filmelf
I would not use a cheaper/lower grade of gasoline for a performance machine and super premium is the GM recomended fuel. Could be trouble down the road using cheap gas.
If you can't afford the gas........You can't afford the car.
The car deserves the best you can put in it
05-17-2007, 02:11 PM
92 Octane which is the highest here.
Arco has the lowest price of Premium Unleaded. I use Chevron
05-17-2007, 02:13 PM
vetdude
Shell V-Power 93. Why quible over $2-$3 difference per tank? If you wanted to burn regular, you should've bought a Camry.
05-17-2007, 02:32 PM
91 in Cali . . . Costco's finest.
05-17-2007, 03:15 PM
SanDiegoBert
Costco uses different brands on a daily basis. Arco is priced close to the Costco price.
05-17-2007, 03:17 PM
Moderator
93. No 91 around here - and that is a good thing! Mine is tuned for 93 octane.
SanDiegoBert
Costco?
05-17-2007, 05:01 PM
jabez
Costco?
The do have gas stations, you know.
05-17-2007, 05:07 PM
SanDiegoBert
I have never purchased gas from Costco but I can see the mile long lines from the street.
05-17-2007, 05:11 PM
burn premium otherwise you wont have all your hprses ready to go.
05-17-2007, 05:19 PM
05-17-2007, 05:26 PM
LS WON
Simple solution: Go when the lines are short or nonexistent. I.E. Early morning, late evening. Works for me.
05-17-2007, 05:27 PM
05-17-2007, 05:40 PM
Ranrich55
For 10 or 12 cents more per gallon, I personally will use the recommended fuel. I've got the BEST vehicle, I'll use the BEST gasoline. Probably wouldn't cause any problems using midgrade, but for only a few bucks per month more, it's worth it to me!
05-17-2007, 06:04 PM
SanDiegoBert
thats the only gas i use....+1% rebate for AE card holders! then again, i dont have a vette....yet, =)
05-17-2007, 09:34 PM
93 locally. On trips some only go to 91.
